Oil filter relocation, known problems?
Old Dec 9, 2011 | 10:21 AM
B5254T4's Avatar
Default Oil filter relocation, known problems?
Want to start by saying that I´ve had my filter relocated this season without any big problems but started thinking when I talked to a Honda guru a month ago.
According to this guy you can measure a oil pressure drop after the install. Two customer S2K´s couldn´t even get into vtec after the install and they had to go back to stock.
When I heard this I remembered my valve lifters started ticking after the install, only for a short while and cold engine.
Feel kinda stupid, should have checked the oil pressure before and after but thought it had to do with the oil brand change.
Sooo, ever heard about this? Easiest way to take care of it? Some sort of valve? Need to have it relocated because of the manifold.
Old Dec 9, 2011 | 10:33 AM
passmans2kny's Avatar
sounds like installation error, theres no reason it should lose pressure if theres no leaks, but u will have to add some more oil once u run a relocation kit
Old Dec 9, 2011 | 10:49 AM
B5254T4's Avatar
Exactly what I thought but he said the extra volume takes the edge of the much needed pressure.
I think they installed it correctly (not that hard) but don´t know milage on the engines, maybe worn down.
Old Dec 9, 2011 | 07:00 PM
H4RD ON's Avatar
I have seen this problem with a customers Sti. It was dangerously lower with the relocation. 40lbs Was not leaking and was on a great well put together billet kit. Ended up taking it off and installing a smaller oil filter.
Old Dec 9, 2011 | 07:28 PM
Phill24's Avatar
Wouldnt smaller lines work for an increase in pressure?...i know alotta of ppl use -10 lines so why not just drop down to -8?
Old Dec 10, 2011 | 12:03 AM
B5254T4's Avatar
I searched for a while yesterday and this is pretty common, here´s a few comments.
* If you switch the hoses you´ll probably kill the engine, it can drop from 40 to 10psi.
* Never use 90 degr bends, it will slow down the oil flow. The adapters shall have straight fittings.
* You will always see a pressure drop with relocation, but normally ok. (Company installing it.)
* Tiny hoses will raise the pressure and big lower it, a size that works on idle might be bad for high rpms.
What do you think, if everything is connected correctly, what can cause a pressure drop with these kits?
And no, I´m not overthinking it, just want to figure it out for the new engine. A lot of $$$...
Old Dec 10, 2011 | 12:09 AM
Phill24's Avatar
So using 2 -10s is bad according to what u found?
Old Dec 10, 2011 | 01:21 AM
B5254T4's Avatar
Phil, don´t know what to think. I run 10´s as well and they should cause a pressure drop but good flow if I understand it correctly.
I´ll try to find more info.
Old Dec 10, 2011 | 09:45 AM
Phill24's Avatar
im looking into it too..im about to go check the pressure on my car
That Guy 1987
Oct 28, 2014 02:55 AM
zeroptzero
Jun 5, 2014 09:16 PM
kent876
Sep 27, 2011 08:44 AM
camuman
Aug 24, 2011 07:27 AM
Tom_B
Aug 15, 2007 09:19 AM
