Oil leak,suspected due to boost?
Old Apr 23, 2016 | 02:11 PM
s2kheth's Avatar
Default Oil leak,suspected due to boost?
Im look for advice from anyone who can shed some light of my oil leak,the car is boosted and running 16psi and had been for a year or so,its an f20c,i think it may be coming from the oil filer(oil relocation kit) fitting on the block, or potientially from the crack seal? The front of the block doesnt show any clear signs or a leak.
My question is,had anybody had any issues due to seal being pushed out because of the pressure
Thanks
Old Apr 23, 2016 | 03:59 PM
Chance S2K's Avatar
Wipe down your oil feed line, drain, and all the fittings. Also clean up all the lines and fittings for your relocation.
Start the car up, maybe with a buddy, and keep a flashlight on all the lines and try to see if you can tell where oil starts to seep through/collect.
Old Apr 23, 2016 | 11:19 PM
s2kheth's Avatar
Ive tried that before i posted on here but with no sucess, and i dont really want to rev the knackers off the car whilst sitting on the spot or jacked up,i even had a look whilst the car was being tuned/mapped the other day
Old Apr 24, 2016 | 07:54 AM
Chance S2K's Avatar
When/how is it burning oil? Do you see a puddle when it's left overnight? Does it lose oil/drip while idling? Does the car/exhaust smoke on startup, or while in boost?
Also, do you have a catch can? If you can't see any leaks first hand then it's possible that your engine is burning oil internally, but more information would be helpful as to when you're noticing the oil being lost, and how much.
Couna777
Aug 17, 2015 10:52 PM
josserman
Apr 24, 2010 10:59 AM
Kwando
Jul 11, 2007 07:22 PM
Chr-2004
Feb 12, 2005 02:37 AM
