Oil press. & oil temp
you will have to install new sending units for oil. and pin them into the aem 1052 -
boost, water temp, intake temps, all can be monitored thru the serial
When I give suggestion on a new builds i now tell people to buy 2 serial guages and a 1052u - with oil pressure sending unit
with that you can monitor
air fuel
oil pressure
water temp
air intake temps
Boost
and what ever else the the computer moniters.
2 guages in the pillar, one with air fuels all the time, the other with water temp, but can switch and moniter them all from both, set up warnings on both..
Takes a while to setup but when it is working it is real nice.
air fuel
oil pressure
water temp
air intake temps
Boost
I have an aem uego and an 1052u...already had the uego and couldnt pass on the deal I got on my ems. Also what makes it hard to set up?
How about wiring this up? Any diy or tips on how to go about this?
I got 2 serial gauges on my car. My tuner had never dealt with the Serial Gauge software before, but he was able to sort it out REALLY quickly. Once one is setup, the other one just installs in-line with that one (via plug). The second one does not need to be setup, it mirrors the settings already done within the system.
I am currently waiting on my oil pressure sender. Here is the part number for that:
30-2130-150
I also ordered an EGT kit too.
30-2050
Never too much information.
Quick question, though, for those who know... The 30-2130-150 also says it does fuel pressure... I take it that it needs a second sensor if you want the fuel reading (as one is on the oil line... no fuel in there)?
Here is a quick pic of my setup (I have tweeters molded into my A-pillars, so I cannot use an SOS pod).
You can never have too much info!
John
30-2130-150
30-2050
John
