Oil Pressure Sender Location
Old Oct 7, 2005 | 11:41 PM
folex187's Avatar
Default Oil Pressure Sender Location
I'm going to install my oil pressure gauge this week and I am trying to get all the mounting hardware together. Is it ok to use a T-fitting mounted where the steel braided line goes out of the VTEC block to the S/C?
Old Oct 8, 2005 | 08:09 AM
John_Z's Avatar
No, don't do that. All that extra weight on one fitting will likely cause the block to crack due to vibration. Run a stainless steel braided line from the stock oil pressure sensor location to a 3 or 4 way tee and mount that on the lower chassis rail. From there you can tee as many senders/lines as you want. I'll take a pic of mine to show you.
Pic added
Old Oct 8, 2005 | 01:38 PM
folex187's Avatar
Hmm... I was thinking about using a T and then an extended hose to mount the sender agains the firewall. Is this not a good idea? I don't think it will add even an ounce more strain on the block.
Old Oct 8, 2005 | 06:35 PM
folex187's Avatar
Here I drew a pic:
Old Oct 8, 2005 | 06:41 PM
Stratocaster's Avatar
Don't do that, do this.
Old Oct 9, 2005 | 11:12 PM
folex187's Avatar
I'm thinking it might just be easier to use the stock sensor location. What thread does the stock sensor use?
S2K-F8
Nov 26, 2014 06:49 PM
lude92_si
Mar 1, 2013 06:09 PM
Moddiction
Mar 15, 2010 01:36 PM
1-S2k-2-NV
Apr 3, 2005 04:30 AM
sfphinkterMC
Mar 7, 2003 03:14 AM
