Oil relocator kit doesn't fit
I am halfway thru installing my inline turbo kit and ran into a problem. The piece that screws in to the stock filter location will not go fully in to place because it is rubbing on the turbo.
Any tips? I was thinking about trying to grind down part of the piece. Here is a pic for reference.
i thought it looked a bit far from the block
here's a legitimate question though, with the factory oil cooler gone will i run into heat issues with my oil? I have lines running to my oil filter but no cooler in between anymore, is the ambient air over the lines/filter enough?
A cheapy oil cooler from Summit or the like should alleviate any concerns about oil temperature. Or if you want to be baller the $450+ greddy oil cooler kit would also work. Oil pressure might start to be affected running oil lines to it a cooler and a remotely mounted filter however. Only way to really verify that last statement is with an oil pressure gauge and a good old fashioned before and after test.
Has any one ran an oil temp gauge before removing the OEM oil cooler and after to verify?
s20004lifehomes
Nov 19, 2009 04:53 PM
