Oil restrictor for precision turbo
Old May 18, 2010 | 11:00 PM
Ek_Jak's Avatar
Default Oil restrictor for precision turbo
hello precision turbo owners! what size restrictor did you guys use for your precision turbo? thanks!
Old May 19, 2010 | 02:27 AM
s2k dre's Avatar
Some use the restrictor that the turbo comes with and a .032 on top of that.
Old May 19, 2010 | 02:33 AM
Deception's Avatar
ball bearing or journal?
Old May 19, 2010 | 05:29 AM
siadam's Avatar
This is the most important part, then of course what motor (assuming f20c/f22c).
Details are your friend, help us help you.
Old May 19, 2010 | 06:23 AM
spdracerut's Avatar
Need more info!
This is like asking:
What size tires do I get for my Honda?
Uh... we talking a Fit or Ridgeline?
Old May 19, 2010 | 10:40 AM
Ek_Jak's Avatar
its a journal bearing precision 5857s .63 ar
Old May 19, 2010 | 11:39 AM
tunedbycft's Avatar
The Precision -4 restrictor fitting that comes on the ball bearing turbos is a .038
Depending on the car, you might need a .032
That fixed my smoking problem.
Hope this could help!
Fernand
Old May 19, 2010 | 11:51 AM
lotus7racer's Avatar
"That fixed my smoking problem."
....and sometimes starving the turbo too.
Old May 19, 2010 | 12:05 PM
Deception's Avatar
I have the same turbo, I just run a -4an feed line & the -4an fitting. Feed comes off the block from stock oil pressure sensor location.
All the problems I had with smoking stopped when I tapped the oil return to the girdle, I would recommend the same.
Old May 19, 2010 | 01:33 PM
Spoolin's Avatar
You dont need a restrictor with the JB Precision turbo's, just make sure youre using a -3 feed line and at least a -8 return line going to the girdle. Also, it may be best to take the oil feed from the filter relocation block on the engine block, but if youre not using a filter relocation block, you can go from the factory pressure sensor area.
