opinions on cometic headgasket?
Hi everyone, im new to forced induction and was wondering if the following cometic headgasket is correct in bore size and such:
http://cgi.ebay.com/ebaymotors/HONDA-S2000...sspagenameZWD1V
Let me know your opinions and also, i was wondering if i can use the factory head studs with the cometic headgasket or would i have to buy apr studs? Let me know your opinions.
thanks
thanks
bore is correct..
that is the stock gasket thickenss by the way..For higher boost you should probably go thicker (over 10 pounds or so) There are a bunch of supercharged guys running around 10psi on stock gaskets. Not really sure about the turbo guys..
