Opinions on these plugs?
Old Jul 17, 2008 | 11:31 PM
jei_s2k's Avatar
Originally Posted by ThatPreludeGuy,Jul 17 2008, 04:50 AM
I'll look into finding a place that had a dynapack for part throttle AFR. I ran my tank down to almost nothing last night and filled up at a different gas station just to see if maybe I was getting some bad gas at the local Mobil (which is very ghetto).
Why would I get part throttle detonation, what would be the causes of that with a stock CTSC kit? I'm doing some investigating into a 7psi pulley and greddy emanage which would solve that because I would have the emanage tuned by a reputable shop. I'm just not sure if I should bother with injectors or leave it be with the OEM ones.
That's a good question but somewhat hard to answer. Sometimes other bolt on's can create lean spots in the part throttle map. Sometimes an engine can have one cylinder fill more efficiently than another whether it be a difference in intake/exhaust runner design, head port configuration, the amount of carbon built up on one piston.... Most respectable tuning systems have single injector compensation where you can increase the duty cyle of one injector to compensate for single cylinder lean issues.
Emanage may not solve the problem since part throttle is in closed loop and any changes made with Emanage will eventually get altered by the factory ecu. EMS or Hondata Kpro and a good tuner would solve this problem.
I've also seen cases where the fuel pump screen was clogged with sediment. You may want to check that and possibly the boost dependent FPR supplied by CT. Make sure the diaphram is still sealing. Check the vacuum lines to and from it as well.
I'd say if you can't find a dynapack anywhere near you. Buy a Wideband O2 sensor from PLX, AEM, Innovate, Zeitronix and check your part throttle yourself. Some of these come with datalogging features that could be helpful.
I know I'm all over the place with ideas. Hope it's just bad gas
EK9MAX
Sep 23, 2014 06:44 PM
ThatPreludeGuy
Feb 11, 2008 07:14 AM
MR2S2K
Sep 12, 2007 05:41 PM
rick bailey
Aug 21, 2006 04:07 AM
