overboosting fix!
ive read some forums and they seem to have similar problems... but not exact same!
my manifold cracked, and i got it re welded... and put all back together.. seems like it was running great! I used a autozone gasket for the wastegate connecting to the manifold its not an exact fit.. and i ordered the real turbonetics waste gate gasket and it should be here tommrow!
3 days ago when i first took it out... ive railed on it and i hear boom popping noise.
the coupling popped off the intercooler piping thank god.. easy fix!
my car is set at 8 psi, but after i put the manifold and everything back together if i get on it... its going to like 15-18 so my ? is do u think im overboosting cause my waste gate is licking threw gasket or is it something else..
thanks
I really appreciate
P.S sorry if wronng forum.. its forced induction but then its also a problem so i wasnt sure ha
ive checked the boost line going to the waste gate and its tight and seems to be ok.
and i dont have a boost controller
thanks
I really appreciate
+1. What setup do you have, i.e. manifold, what turbo, and your choice of controlling the boost. It can definitely be another crack in the manifold but discrepancies in your vacuum and boost sources can cause this as well.
whats your set-up? from what it sounds like... your using a cheap set-up and using a boost control to keep it at 8lbs of boost...
what turbo do you have? what size exhaust do you have?? Etc.... thers alot of important information missing
its the exact turbo kit off of the gold s2k from drivers image if your familiar with that... its a garret 51 trim... turbonetics evolution waste gate..turbo rev hard steel manifold.. i dont have a boost controller
there is two nipples on the waste gate one on the chrome piece and one by the dump tube.. n i hooked the vacuum line up to the waste gate and the other nipple is 4 a boost controller right?
hope this helps any!
let me know if u need more info
LiamR
Dec 5, 2015 12:11 AM
