p1259 still
Hey bro, just an fyi....just cause you havent lost any oil doesnt mean your oil pressure cant be low. Happened to me with a bad oil pump. Oil level was fine, but i was only hitting 35-45psi.
Good luck!
Good luck!
But would the oil pressure drop off at that level, yet be enough to engae it?? I certainly hope its not the oil pump, as that is no easy replacement item. I plan to switch to AEM before spring and get rid of the piggy back bs.
My dyno times have been fine. It only happens in the higher gears when I am in vtec for awhile. That would tell me the oil pump is working at least until a point. I know it needs 50ish pounds to flip the switch on and then off but why would it fall once it is at that rpm level?
