eManage Setting Info
Old May 14, 2006 | 03:56 PM
batikan's Avatar
Default eManage Setting Info
I haverecently bought an eManage with Boomslang Pnp Harness. I am having some difficulties adjusting it though.
1) On the ain Unit Settings, the screen must be like this:
On the S2000, the Rotary SW1, SW2, and SW3 must be 4-8-C, mine is like that
The rest is also the same except my Airflow Meter 2 shows "Aux-out" instead of "VTEC-out" and AirFlow Meter Pulse input shows "Aux-in" instead of "VTEC-in"
2)I heard that the eManage does not work with the Vortech FMU. I don't know how to take mine out. Anybody know how to do it?
3) I do have the eManage Map Sensor, so should I clickon where it says Absolute Pressure Sensor? becausein the description it says this function is used when the system exceeds the factory MAP sensor capacity.
4) The VTEC settings screen is differennt than the one on the manual which is:
mine shows something like an excel screen and it shows 4000-5000-6000-7000 forthe columns and underneath 4000 it says OFF OFF OFF OFF,underneath 5000 it says OFF OFF OFF ON, underneath 6000 OFF OFF ON ON and underneath 7000 it says OFF ON ON ON.
What could be the reason the screens are different? Do I need to update the software or is it because something is wrong and that's why it shows "Aux-out and Aux-in" instead of "VTEC-out and VTEC-in'?
5)My car has idle problems. There is an Anti Engine Stall Setting on eManage which looks like this:
What do these numbers mean?? Can someone provide me more info?
THANKS FOR ALL THE HELP...
Old May 15, 2006 | 05:27 AM
stitos2k's Avatar
Not trying to be a jerk, but Emanage is NOT for the idly curious. Take it to a shop who knows how to tune, PERIOD! You mess this up, you WILL destroy your engine.
Don't install it, don't screw with it unless you know what you are doing before hand. To tune it properly you need to have it put on a dyno anyway, so you might as well wait.
You REALLY don't want to pay $7000 to have a new engine installed.
A1ex
Apr 2, 2014 04:30 AM
GreeceS13
Αγοραπωλησίες
Jun 19, 2013 01:22 AM
Sub2K
Sep 26, 2008 07:01 PM
kylemonster85
Aug 30, 2007 11:00 AM
batikan
Apr 18, 2006 04:09 PM
