Partial throttle misfire
Old Apr 3, 2013 | 01:56 PM
neoleooo's Avatar
Default Partial throttle misfire
Iv'e been having problems with partial throttle misfire. It mostly happens after the car is driven over 15 minutes. WOT feels fine it's only partial throttle that's the problem. Here's my set up:
Full-Race kit
Flashpro
E85
Deatchwerks 1300 injectors(new)
Ngk8 ird plugs (new) gaped at .023
Have six error codes:
misfire cylinder 1,2,3,4
random misfire
evap emission control code P0455. Anybody Know what this is?
Thing I'm planning to do:
disable primary o2
Install Kenne Bell BAS
Any other advice would be appreciated. Thanks!
Old Apr 3, 2013 | 02:36 PM
spectacle's Avatar
Post a log with timing, AF, and MAP when its happening. That will help us help you.
Old Apr 4, 2013 | 04:24 PM
sohc_mshue's Avatar
I doubt your problem is weak spark if it does not misfire under load
Old Apr 4, 2013 | 10:53 PM
neoleooo's Avatar
that's what i was thinking too. maybe i don't need the BAS. Do you know what this error code "Evap emission conclol" is?
Old Apr 5, 2013 | 04:37 AM
sohc_mshue's Avatar
It is something likely not related to your problem. Something must be malfunctioning in the evap system.
vtecjstkiktinyo
Jun 28, 2013 09:37 AM
whiskeybill8
Feb 8, 2011 09:28 AM
AP2_s2000
Jul 11, 2010 09:59 PM
reds2k00
May 27, 2009 03:56 PM
