CEL Code Troubleshooting Random Misfire and Lean Condition
Old Jun 26, 2013 | 10:47 PM
vtecjstkiktinyo's Avatar
Default CEL Code Troubleshooting Random Misfire and Lean Condition
Just bought a MY02 S2K last week, 78k miles. Next day I started getting CEL for P0170, P0171, and later P0300, P0301, P0303, P1399.
Using this forum I tried the following: Cleaned MAP Sensor. Cleaned throttle body. Cleaned IAC valve. Checked for vacuum leaks using propane- no leaks found. Reset ECU for idle mapping. After that, the car ran noticeably smoother.
Codes showed up again. Checked spark plugs. Plugs looked good, but gaps were OOT- the worst was about .065. Replaced spark plugs with NGK Laser Irridium plugs. Car ran even better. Cleared codes.
Codes showed up again. Swapped coil packs, did cylinder compression test. Compression was awesome (didn't really think this was a problem, but wanted a baseline for compression anyway- now I know for future reference.
Codes showed up again, random misfiring. At this point I am thinking the random misfire suggests it's not isolated to something like an injector, or coil pack- seems to happen to everything. I had been suspecting the front O2 sensor, even though there's no O2 sensor specific CEL. O2 sensor came today so I swapped it. See my DIY post for that if you have questions. The car runs really smoothly now. The idle was noticeably better, response is better when I let off the throttle in neutral, and the car seems to shift better at cruising speeds. I never seems to have trouble at WOT or engine warm-up, BTW.
I also don't suspect it is a fuel pump, only because that would be very uncommon for a car with 79K miles and only 11 years old, IMO. Time will tell if the O2 sensor has resolved the issue. I hope so. I will keep this updated. If the problem persists, I have heard there is a method for checking injectors using an ohm meter and checking for resistance differences from injector to injector. I might also try swapping injectors to trace a moving problem, but so far the misfire was random. I just don't think all injectors are going bad intermittently, or the coil packs.
May the VTec be with you.
**UPDATE** The 02 sensor seemingly was the answer. No trouble codes since.
Old Jun 27, 2013 | 12:22 AM
S2KiChad's Avatar
maybe dirty injector/fuel pressure or bad gas? anyway good luck looks like your on the right path
Old Jun 27, 2013 | 05:06 AM
MR.T's Avatar
Your first two codes are O2 codes. It's always best to resolve them in order.
If an O2 code goes too long unchecked it'll start to cause misfires, which in your case it did, and eventually could result in catalyst damage. I guarantee replacing the O2's fixed your problem.
I've had a few engine problems on my S and every time the motor isn't happy it affects shifting smoothness tremendously. Just my observation.
Old Jun 27, 2013 | 05:12 AM
MR.T's Avatar
At least you found out that the plugs needed to be yanked and you have good compression.
Old Jun 27, 2013 | 05:45 AM
charlesardolino8's Avatar
I'm having a similar problem with my02 were its misfiring under full throttle and after warm start up!
Old Jun 27, 2013 | 07:08 PM
Thanks for the feedback everyone. Drove the car to work, to the DMV, the gym, and home today. No CEL so far. Drives great. Love this car. I think the O2 sensor was the culprit- but I am glad I did everything else anyway. Runs smooth and I got to know my car a little. Not bad for my 1 week anniversary
Old Jun 28, 2013 | 09:37 AM
s2000maniac's Avatar
My buddy had the same issues and it was dirty injectors.
saving4one
Jul 3, 2016 09:10 AM
1.8TsBLOW
Apr 29, 2008 05:29 PM
elude
Nov 18, 2006 04:55 AM
Stko0k
Aug 27, 2006 03:08 PM
Rawhide
Apr 5, 2006 01:27 PM
