Passenger side brake line relocation
Old Sep 9, 2012 | 08:13 AM
s2guru's Avatar
Default Passenger side brake line relocation
Guys,
I know many of us just wrap the line with some type of heat blanket and/or push the brake line away from the turbo manifold. Now, how about relocating just that line?
will a regular -3 ss line work? with the correct fittings of course. I know some guys have relocating the whole thing ( ABS + lines ).. Pictures? suggestions?
Thank you
Old Sep 9, 2012 | 08:23 AM
passmans2kny's Avatar
good idea, I always wanted to get rid of that line, in for info on this one
Old Sep 9, 2012 | 08:56 AM
herecomesboost's Avatar
I just bent mine slightly for the time being. Yes, you can use a -3 line if you'd like (the factory lines are 3/16"). You will need -3AN-->10x1.00 adapters though (for the inverted flare connections).
Old Sep 9, 2012 | 09:04 AM
This is what I did with my Civic:
Old Sep 13, 2012 | 06:01 PM
s2guru's Avatar
^ thanks, but i will like to see it done in the s2k.
Old Sep 13, 2012 | 06:06 PM
The concept is the same. Do you want to run the line behind the firewall? You'll need two bulkhead fittings (-3 AN double male), two -3 AN --> 10mm x 1.0 (double male) fittings, and three -3 AN lines (one to go from the ABS unit to the bulkhead on the firewall, one to go from the inside of the bulk head on the interior side of the firewall to the bulkhead on the pass side fender well, and a third line from the fender well bulkhead to the inverted flare stock line (just like my Civic pic above). Let me know if you have any questions.
Old Sep 14, 2012 | 07:15 PM
miguel329's Avatar
Yup same shit, diff car
Sent from my PC36100 using Tapatalk 2
Carbon S2K
Apr 5, 2015 10:21 AM
Dizings2k
Jan 19, 2015 08:07 AM
nitewing117
Bay Area For Sale
Sep 23, 2010 12:24 PM
skool u
Sep 19, 2009 07:59 PM
nickrg3
Feb 12, 2006 02:11 PM
