passman's turbo build
looks like he did more than roll the fenders, they are flarred out, i have a simple roll and im not rubbing at all with the 275s, if im holding at this power level i see no need to go to a 315
A good tire is better then a wider tire. But both = bliss. That ring said don't get caught uP in fatest tire u can fit. Remember guys with 700whp run 255 wide drag radials and run fast.
That being said either drag radials or r comp tires are your best bet. Passman holds on r comps.
I speceial ordered a set of VS-SS 3-piece a few years back:
My Rear wheel / tire size is: 285/30/18 tire on a 18" x 10" wheel, offset is +71
I don't have the fenders rolled, am lowered 2", and can run normal camber settings (am at -2.0 in rear), the wheel / tire does not rub at all, and the OEM rubber fender-liner is still completely 100% intact.
Anyone who's interested should check out their website or give them a call.
