PCV Question
Old Apr 9, 2010 | 11:57 AM
X-RAYED's Avatar
Originally Posted by siadam,Apr 9 2010, 01:47 PM
funny, thats what I was thinking about doing, then running a line from it.
That is the EXACT one you have?
If so I'll get that ordered asap
Yep, link copied directly from my Summit account.
Edit: I put a 8- AN 90 degree on the above fitting, and ran a 'twist-tite' hose directly to a vented catch can with a 8- AN. I did the same with a vented oil cap.
I recommend planning your assembly thoroughly prior to buying parts.
Old Apr 9, 2010 | 12:04 PM
siadam's Avatar
Yea, I always do. I had to order all my fittings/etc for the oil feed/return a while back plus some other odds/ends.
Otherwise S&H will kill you on ordering just 1 part.
Old Apr 9, 2010 | 10:52 PM
neeman77's Avatar
I just also bought one of these.
http://www.lightningmotorsports.com/vibran...71/i-70432.aspx
So now I have two 1/2 lines coming out of the valve cover plus one -8 AN off the oil cap
Old Apr 10, 2010 | 10:32 AM
camoy's Avatar
Originally Posted by X-RAYED,Apr 9 2010, 11:35 AM
You can buy this:
http://www.summitracing.com/parts/RUS-670491/
I run it, and it works perfect, no drilling tapping etc.
+1 I use this on my setup as well, IMHO it is a better way to do it than welding on nipples. Since it is baffled already less oil in the vapor that escapes, plusno more EGR valve to let boost in the manifold get by.
Old Mar 20, 2011 | 01:15 PM
pwrofdrm's Avatar
Sorry to bump this from the dead, but can anyone tell me where to get a 14mm x 1.5 to hose barb fitting? Also, just incase you're wondering, the AP2 S2000 PCV valve thread is NOT 3/8" as others have stated above.
Old Mar 20, 2011 | 08:46 PM
Deception's Avatar
If you cant find online, try Mooreland hose in Oakdale
Old Mar 20, 2011 | 08:54 PM
Deception's Avatar
Is that Vibrant oil cap adapter baffled?
Old Mar 21, 2011 | 07:26 AM
siadam's Avatar
I can't remember, but I never had any issues. Seems like it was sort of.
Old Mar 21, 2011 | 04:06 PM
Boofster's Avatar
A note of warning on the Vibrant cap, I just ran a track day with it installed and a whole bunch of oil overflowed out of the catch can. I'm assuming there is no internal baffle on the valve cover to put an outlet at the oil cap. I wouldn't use this ever again.
Old Mar 21, 2011 | 06:37 PM
Blucky87's Avatar
so a 14mm x 1.5 to hose barb fitting will fit in there?
