PFab Top Mount with a 5857
Old May 11, 2011 | 07:54 PM
Corey Maurer's Avatar
Default PFab Top Mount with a 5857
Anyone know exactly what I will need as far as fittings and such? This is my first turboed car, I have had supercharged but dont know EXACTLY what I need as far as oil lines for my turbo.. I have bult a bunch of stainless lines before tho so I would like to just peice together some quality lines.. anyhelp would be awesome!
Old May 12, 2011 | 04:32 AM
o'malley_808's Avatar
I just went through all this with my setup. The feed side of the turbo is a 1/8NPT thread. From this you can choose to get an adapter to a -3 or -4 (Both will suffice just the -3 will be smaller and more likely cheaper to purchase). Your also going to need to get some 1/8NPT fittings to T into the oil pressure sensor. About a 1 1/2' of -3 line should be more than enough. I would also recommend one of the turbo oil restrictors with a filter like me and siadam run. However these only come with -4 fittings so then your back to -4 for all your setup.
As for the drain get -10 and then tap into the girdle with a 1/2" NPT pipe thread. You'll need about 1 1/2' of line again here also.
Hope this helps.
Check my thread for more pics.
Old May 12, 2011 | 09:28 AM
Ok cool.. anyway you could PM me like a shopping list? I would like to run the proper oil restrictor and all... and -4 is fine with me.. and I will order 2 feet of both of the lines to make sure I have enough!
Old May 12, 2011 | 09:38 AM
As for the flanges that go onto the turbo itself, are these two good ideas for the 5857? and will they fit?
-3an Inlet with built in restrictor
http://www.advancespeedshop.com/func...3-p-14082.html
-10an Outlet
http://www.advancespeedshop.com/func...0-p-14079.html
And then I would need a 1/2"NPT to -10an fitting for the girdle (which you are all just drilling and tapping I assume? what about metal shavings? is it possible to weld? if not how nything you reccomend for a seal? and where do I run the oil inlet line from?
Old May 12, 2011 | 09:57 AM
3en's Avatar
3en
You can can get oil feed from the oil pressure switch. BE CAREFUL when tightening it. Also it is a 1/8" bspt not npt. Ive known and read threads of people whe went to Ace hardware and bought a brass 1/8"to1/8" npt fitting and overtorqued it and cracked the block. Most people are fine just tapping the girdle and using a thread sealer, Welding is not really needed.
Old May 12, 2011 | 09:58 AM
They have a -4an inlet with built in restrictor as well.. so with those 2 flanges and these following parts would I be all set??
1/2INCH to -10AN Fitting tapped into girdle
(2) -10AN 45 Degree (guessinf those would be best? what degree is everyone else using?
(1) -4an 90 Degree for straight off the turbo
(1) -4an 45 degree off the tee (where do I get a tee?) (and is 45 degree right or should I go 90? Straight?)
3 foot of -4an stainless
3 foot of -10an stainless
and a tee off oil line? Where do I tee into? where do I buy a tee?
Old May 12, 2011 | 10:08 AM
can someone link me to the right tee? sorry for sounding like a tard lol
Old May 12, 2011 | 10:14 AM
3en's Avatar
3en
http://www.treadstoneperformance.com...dapter+Fitting
Tee into the oil pressure switch above the filter. or do it the safe way and buy a sandwich plate and go directley into that.
Old May 12, 2011 | 10:16 AM
what else would I need with that fitting? I take it the male part threads into the block and the pressure switch threads into one of the female ports.. then I just need an NPT-AN adapter for the feed line correct? What size are the female threads? and is that male thread BSPT?
Old May 12, 2011 | 10:19 AM
If I bought the one you linked and this one here I would be set to run -4an line correct?
