Pics of my SPARK PLUGS, how do they look?
Old Jun 27, 2009 | 12:12 PM
JoeyBalls's Avatar
Thumbs down Pics of my SPARK PLUGS, how do they look?
Hey guys, I pulled my plugs just to see whats going on, I am usually no leaner than 11.0 WOT so I dunno, I figured I would not have any signs of detonation, but there seems to be a tiny amount, could be from SPIKING, U dunno
Anywhay I have the NGK Irdium BKR8EIX
What does all that CARBON build up mean on the base?
Old Jun 27, 2009 | 02:51 PM
MaseEngineering's Avatar
Banned
they dont look bad, but too rich, and timing doesnt seem to be optimal.
Old Jun 27, 2009 | 03:00 PM
JoeyBalls's Avatar
thanks, too much timing perhaps?
its amazing that you can tell that from a plug, pretty cool
Old Jun 27, 2009 | 03:02 PM
AndyFloyd's Avatar
joey the black base of the plug indicates you are a little bit rich, so your small signs of detonation on the porcelain are likely from timing as mase has said. We know your not lean.
Old Jun 27, 2009 | 05:36 PM
Spoolin's Avatar
Get your A/F closer to 11.5-11.8 and pull about a degree of timing out of it all they way through.
Old Jun 27, 2009 | 05:41 PM
JoeyBalls's Avatar
wish I knew how ,
Spoolin, what the hell is i like to have 440tq, that is just insane
Old Jun 27, 2009 | 05:52 PM
Spoolin's Avatar
Originally Posted by JoeyBalls,Jun 27 2009, 08:41 PM
wish I knew how ,
It's pretty insane and launchs like a freaking rocket. Well, it did until I ended up blowing the HG. I was running just a tad too much timing for the 60-1 turbo and that was the result, pushing that turbo too hard. I'll have it back up and running soon hopefully but with a Precision 6262 or AMS 850R turbo and hopefully keep that torque but be closer to 700 whp when I do.
Old Jun 27, 2009 | 07:52 PM
JoeyBalls's Avatar
awesome man, I cant wait to hit 450+RWHP I am more of a Torqe freak though, insnae numbers you have, f---- awesome.............
Old Jun 27, 2009 | 08:06 PM
m R g S r's Avatar
How did you pull the plugs to take pics? Because you are supposed to cut the ignition under the desired load and rpm you want. Say you were running rich at the load/rpm you wanted to check and then you let the car idle and it is lean at idle...that will change the way the plugs look and may give you a false reading.
Old Jun 28, 2009 | 12:22 AM
Riceboi's Avatar
I think this guy needs his own kill section haha
usafstud
Jan 11, 2012 08:10 AM
EastS2k
Mar 11, 2011 11:06 AM
houstonpv
Nov 14, 2009 01:54 PM
S2Krazy
Sep 21, 2008 10:52 AM
goldenfri
Apr 16, 2006 10:02 PM
