please input on turbo comparison
Old Nov 16, 2008 | 11:24 AM
08s2000CRbackinblack's Avatar
Default please input on turbo comparison
on my civic i had a sc-61 on a log manifold and a gt40 on a fullrace top mount manifold. overall i like the sc61 because it spooled quicker and didnt need vtec to spool it like the gt40 did. i am looking into which turbo to boost my s2k with but am not sure if i should go with a sc-61 again or go bigger. i was going to get inlinepro sidewinder manifold which is a t4 manifold. so i was looking into the smaller t4 turbo T-T4/60-1, what would the spool be like compared to the gt40? quicker than the gt40? slower than the sc-61? i REALLY like that this turbo has the vband unlike the sc-61. i am going to boost the stock engine at first but will eventually build the bottom end. and input is greatly appreciated, THANKS!!!
Compressor Specifications:
-60-1 compressor wheel with a max flow rate of 61 lb/min
-0.70AR T04S compressor housing
-Good to 585 whp.
Turbine Specifications:
-p trim turbine wheel available
-0.68 AR , 0.84 AR, 0.96 AR tangential housing options
-v-band turbine discharge
Old Nov 16, 2008 | 11:38 AM
kutsujula's Avatar
what about a t4 t67?
Old Nov 16, 2008 | 12:38 PM
how would that turbo spool? quicker than a gt40? i want to be boosting by at least 5000 rpms. the t4-61 is only rated for like 50 more horsepower than the t3-61. i want something that will hold big numbers once my block is built but still not take a year to spool. im favoring the t4 because of the vband but i want to make sure it want be so laggy its annoying. i dont want to have to wait to spool the turbo after each shift
Old Nov 16, 2008 | 12:41 PM
what turbo are you running? what psi were you pushing on pump gas to make 400+ hp on the stock block? headgasket?
Old Nov 16, 2008 | 02:46 PM
kutsujula's Avatar
I was running a t3 gt3582r with a .82 ar
It made 422 on pump, 543 on c16 all stock block and stock headgasket
Old Nov 16, 2008 | 03:01 PM
how much boost on pump gas? how would the t4 -61 or 67 be? i think the 67 may be too laggy?
Old Nov 17, 2008 | 04:35 AM
kutsujula's Avatar
8psi.
I would think the T67 wouldnt spool but a couple rpms later then the gt35r and if he is looking to build the motor it should do well.
Whats the power goals?
Old Nov 17, 2008 | 09:37 AM
2big4aS2000's Avatar
i have a car running a gt40, on my tubular manifold - boost takes sooo long to come on, but when it does the car shakes as it sticks you in the trunk. It is stupid fast, but not fun to drive, on the other hand we also did a gt3076 on our manifold, 19lbs - 750 injectors on stock block with 3mil head gasket - 500hp, and full spool was at 3400 rpm, that car was a blast to drive, even had the 2 step setup for launch, no mercy and with drag radials i swore it was pulling front tires off ground (that is what it felt like).
Old Nov 17, 2008 | 09:48 AM
kutsujula's Avatar
Any more info on the gt40 setup?
Old Nov 17, 2008 | 10:55 AM
i dont have any particular power goals. i ran c16 in my civic on high boost but think im gonna tune specifically on pump gas for the s2000. i think the t4-61 would be a good medium between the gt35 and the t4-67. think so? this turbo would still be able to push 600+ hp. im probably just gonna out low compression pistons and rods in the block but not sleeve it so i dont know how much boost i can safely tune on pump gas with stock sleeves
