PnP Harnesses all the same?
Old Feb 6, 2014 | 07:53 AM
Pinky's Avatar
Default PnP Harnesses all the same?
I have a set of RC650's with the PnP Harnesses. I am going to have to upgrade to 1000's for the level of boost I will have. Was wondering if the harnesses are all the same or do I need to stick with a certain brand/style?
Thank you for your response.
Old Feb 6, 2014 | 08:19 AM
pwrinxs's Avatar
I can't really answer your question but you should consider hard wiring them. I have the harness with id1000s and although I'm not having check engine light problems now, I did for a while and Evans Tuning told me it's a common issue with pnp harnesses. After fiddling with them a bit, my CEL disappeared and has been gone for a while. Keeping my fingers crossed!
Old Feb 6, 2014 | 08:56 AM
S2-Kai's Avatar
They are NOT the same. RC injectors iirc, use the obd1 style connectors, while the Bosch injectors use the ev14 connectors. You can de-pin the connectors and swap them to fit the new injectors (making it look stock).
Old Feb 7, 2014 | 07:30 AM
Pinky's Avatar
Oh you mean DE-PIN the OEM injectors connection and plug into the other harness(take out the middle man connection)
I guess the question is should I then just get RC injectors in the 1000 series and thus the connection would still be the same or is there a benefit to using a different brand/style?
Don't get me wrong I am VERY capable of hard-wiring just like the ability to go back to stock if needed but won't do so at the risk of reliability.
Old Feb 7, 2014 | 10:16 AM
S2-Kai's Avatar
Yes, de-pin the stock connectors and insert the stock pins into the new connectors (requires a pick tool). Ive heard Rc injectors are harder to idle but haven't had personal experience.
Old Feb 9, 2014 | 04:34 PM
S2K@PR's Avatar
what was the CEL code?
i recently had some issues also and messed with them a bit and now issues are gone... fingers crossed here also!
Old Feb 9, 2014 | 06:04 PM
Pinky's Avatar
Preferences on possible injectors that plug into the OEM harness?
Old Feb 10, 2014 | 12:24 PM
wadzii's Avatar
Banned
rc1000's suck.. spend the money to get ID and dont use the pnp clips. Every other car with pnp clips has issues and I have to hardwire them anyway.
I change the pin and use the proper connector. I have about 500 oem style pins and tons of stock connectors so if you want to go back to stock its not hard.
vader1
Aug 13, 2009 08:12 AM
my01s2k
Feb 20, 2006 09:03 PM
jdnissanz
Nov 19, 2005 06:33 AM
BLOWNJROCK
Jul 27, 2005 10:26 PM
