Poor Drivablity with Thicker Head Gaskets
Old Jul 31, 2010 | 07:55 PM
  #21
dsddcd's Avatar
[QUOTE=Revenge,Jul 31 2010, 08:45 PM] I have the ILP 3mm HG and I have no such issue.
Old Aug 1, 2010 | 03:30 AM
  #22
s_d2k's Avatar
Originally Posted by kutsujula,Jul 27 2010, 02:20 PM
I made over 500 on 93.
Factory hg motor etc
how much boost?
do you still have this dyno ??
Old Aug 1, 2010 | 04:39 PM
  #23
Revenge's Avatar
Maybe cause I run 93 it just runs better than 91? My car also idles kind of high cause of the larger injectors. I would not call it butter but its not bad at all, way better than when I had the e manage.
Old Aug 1, 2010 | 07:28 PM
  #24
m R g S r's Avatar
I made 500 on pump as well factory HG 93 octane. still running
Old Aug 1, 2010 | 08:24 PM
  #25
Angerman's Avatar
Originally Posted by elmisterioso666,Jul 27 2010, 11:50 AM
yea i have the 3mm nd is bad i have tryed playing wit the timming there nd does nothing
I keep hearing all these things wrong with the 3mm HG, should I not get one? (Goal is 350-400whp for a DD) and keep the factory hg?
Old Aug 2, 2010 | 03:32 AM
  #26
Revenge's Avatar
You should not need one for those HP goals. It also depends on the kit your gonna use.
Old Aug 2, 2010 | 04:50 AM
  #27
teamvalorracing's Avatar
^for 350-400whp, definitely keep your oem HG.
Old Aug 2, 2010 | 08:29 AM
  #28
Soul Coughing's Avatar
i found no difference between a 3mm HG and stock HG. What i did find was an increase in fuel mileage by at least 3-4mpg. That is, going from 3mm headgasket back to stock HG.
Old Aug 2, 2010 | 10:10 AM
  #29
dsddcd's Avatar
I talked to Jeff Evans today and he suggested that I check all my grounds before I go any further.
Old Aug 3, 2010 | 05:47 AM
  #30
1SlowSi's Avatar
I may have experienced something similar during part throttle around 2-5k rpms but it goes aways once the car is warmed up. Probably not what you are experiencing.
