Ported IM / Fullblown TB
Old May 31, 2012 | 02:16 PM
  #21
gsx2004's Avatar
very clean, nice job
Old May 31, 2012 | 04:00 PM
  #22
S2SEXY's Avatar
how would a bigger TB help if your using charge pipes that are smaller then the tb?looks great btw
Old May 31, 2012 | 07:27 PM
  #23
Irishflame27's Avatar
dumb question but is the manifold 100% metal finished, or did you use any kind of metal filler (metal glaze) to reshape the lines on top of the plenum prior to powdercoating?
Old May 31, 2012 | 07:31 PM
  #24
s2000Junky's Avatar
Originally Posted by S2SEXY
how would a bigger TB help if your using charger pipes at are smaller then the tb?looks great btw
Was thinking the same thing. Small looking pipe
Old May 31, 2012 | 09:22 PM
  #25
Corey Maurer's Avatar
okay so I have used a grinding wheel, flap disk, and sawzall (LOL) to get all the stuff I want gone gone, what are you using to hand sand with grit wise? wet or dry? any help would be awesome.. I also went a bit different route with mine so I wasnt copying you
Old May 31, 2012 | 09:24 PM
  #26
AHHH I see how you did those coolant loines... you just tapped them for screws? smart! The two coolant lines on the front of the manifold (valve cover side) do I have to keep those? I know one is a bleeder valve or something..
Old Jun 1, 2012 | 10:13 AM
  #27
S2K-F8's Avatar
No filler used, just a LOT of block sanding
Old Jun 1, 2012 | 10:29 AM
  #28
S2K-F8's Avatar
I think I used 50 and 80 grit dry, then 400 grit wet (for block sanding). Then I did a lot of the finer stuff with a 90 degree die grinder and various 1" and 2" sanding pads (mostly fiber discs)
I opted to keep my bleeder valve (since this car is such a b*tch to bleed!), but I imagine you could do away with it if you wanted. The other line right by the bleeder valve I just cut off, tapped and plugged with a screw. I would have had this hole filled if I could have got the steel insert out, but you can't punch it in like the others (no way to get it out if you do).
Old Jun 1, 2012 | 10:34 AM
  #29
S2K-F8's Avatar
Yea, the charge pipes are 2.5" I think (whatever comes with the full-race kit)
I'll probably get flamed for this....but I did the FB TB more for looks than performance. I didn't want to put all that work into customizing my intake manifold then bolt the ugly stock TB back on.
Old Jun 1, 2012 | 07:00 PM
  #30
Lmao, no flames here.. I did it for the San reason although I have 3 inch charge pipes do I guess it's worthwhile
s2000ellier
Oct 4, 2016 04:37 PM
topfuel
Jan 26, 2011 12:51 PM
weiRtech
Sep 30, 2009 11:11 AM
weiRtech
Aug 16, 2007 03:28 PM
