Possible MAP sensor problem?
Old Sep 17, 2008 | 06:24 PM
9kFever's Avatar
Originally Posted by TRBOKEV,Sep 17 2008, 01:51 PM
The only reason I haven't gone and got the tune yet is that I was in the process of working a few bugs out on the car Before I went and spent the 400 dollars on the tune.
I just don't see the point in going for a tune and spending the 400 only to go and spend another 400 for a re tune after I fix things...
I have a wideband on my car so I don't see a problem running the stock map for now since I am monitoring AFR's (which are rich)
I just got to figure out this problem before I go and get my tune.. This crap going on with my car isnt normal even with the base map..
It shouldn't be 400 for fine tuning considering the majority of the tuning would be already done the previous session. The point of it is you are seriously risking your motor. The tuner will more than likely either fix or give you an idea on what needs to be worked out.
Old Sep 17, 2008 | 07:11 PM
sawgei's Avatar
Have you check the TPS? If you have a bad TPS or a flat/dead spot it will also cause your car to bog.
Old Sep 17, 2008 | 08:42 PM
TRBOKEV's Avatar
Swapped the map with the one from my 97 Acura CL right now...
Car runs good again and the wideband is much more steady. Partial throttle AFR's are back in the 11-12.5 range and WOT is back to 10.5-10.8. Seems like I found the culprit. I will know for sure in the next couple of days.
Got to get my downpipe finished and my tune done now.
Old Sep 17, 2008 | 09:45 PM
Kirpich's Avatar
MAP clamp in Emanage?
Old Sep 18, 2008 | 07:08 AM
TRBOKEV's Avatar
Car ran fine again this morning.
Looks like the MAP sensor was the problem. Phew!
Old Sep 18, 2008 | 12:57 PM
brilliant's Avatar
anyone have any idea which map sensor I need to run for over 10psi with my setup?
Old Sep 18, 2008 | 01:06 PM
s2kadl's Avatar
After a suggestion from another member , I am going to try the Omni 4 bar map sensor because it is plug and play, no slicing needed and its factory dimensions mean easy mounting. I am using it with an AEM not sure if you can use it with the ULT.
http://www.omnipowerusa.com/product.asp?P_ID=133
Old Sep 18, 2008 | 01:34 PM
brilliant's Avatar
it says compatible for 2006+ s2k.
Old Sep 18, 2008 | 01:53 PM
s2kadl's Avatar
If you look further up on the page the map sensors suit the s2000 00-05 which i think is the B series one. The k series one is for the s2000 06+
Applications:
Honda civic 88-00 all models
Honda accord 94-02 all models including V6
Honda CRV 97-01 all models
Honda Del Sol 93-97 all models
Honda Odyssey 95-01 all models
Honda Prelude 92-01 all models
Honda S2000 00-05 all models
Old Sep 18, 2008 | 02:42 PM
brilliant's Avatar
ahhh i see, does anyone know whether or not it is compatible with emanage ult?
I really do not want to blow my motor.
