precision 600hp intercooler.
Old Jul 30, 2006 | 09:09 PM
AusS2000's Avatar
I have a PWR 600x300x76mm. Not sure how it compares hp wise.
It is in the same position. I modified the condensor bracket so it sits futher back.
But instead of the L brackets I use some slotted angle iron and made a brace that uses two existing bolts on either side and then the cooler is hung from the brace with threaded rod (M8 I think) as it has threaded nuts welded top and bottom.
At the bottom I made a V shaped bracket that attaches to the upright just below where the horn used to be. Each arm protrudes to the bottom captured nuts. It doesn't support any weight but holds the IC in position.
Old Jul 31, 2006 | 02:35 AM
ex-eclipse's Avatar
Originally Posted by herecomesboost,Jul 30 2006, 11:43 PM
hey ex-eclipse, are you sure that you have the 600? that looks like precisions 750hp intercooler.
Kyle R
I think you are right, it is the 750. I can not remember for sure but it is the one that comes with the LoveFab kit.
Old Jul 31, 2006 | 06:44 AM
GDM S2K's Avatar
I had a custom one made locally-
boostovereverything
Feb 21, 2012 06:39 PM
suzuka-blue-s2k
Dec 15, 2008 02:10 PM
import guy
Dec 13, 2008 06:01 PM
ccs2000
Oct 14, 2007 10:24 AM
europa
Mar 7, 2007 03:56 AM
