Precision 6262/6265
Originally Posted by Peter@ISP,Mar 10 2009, 12:17 PM
i just installed this turbo on my car. so far so good. having boost tapering issues though. im going to upgrade my intercooler and up my timing to see if it helps
Originally Posted by leo520,Mar 12 2009, 12:15 PM
i think they burn 2x times faster than the regular oil right??
Originally Posted by Full Race Geoff,Mar 12 2009, 11:24 AM
interesting to see the powerband, only making 200hp/ftlb until ~5200rpm. what manifold and turbine housing are you using? tq dropping off like that is usually indicitive of high backpressure which could be solved with a larger turbine housing, but with the repurcussion of later spool.
here is what i found so far
-compression is 160 all the way across (i believe it might be because of head porting?)
-i have small intercooler so that might cause boost to drop 4 psi?
-i found small boost leak around throttle body
-i was using low spring so that might cause it too
the manifold im using is lovefab minime with the t4-t3 adaptor on top of it. never had torque drop off like that with other turbos but than again i never turned up my boost to 30 psi...
Originally Posted by 2QYK4U,Mar 12 2009, 01:47 PM
I am sure you meant to say "burn 2x times faster than the regular gas". If so, E-85 burns about 30% quicker. However, most people who use E-85 don't care about fuel consumption--they are looking for a cheap high octane fuel. E-85 is ~104-105 octane and costs ~$2/gallon. C16 is ~117 octane but costs ~$14/gallon. Unless somebody is going for a power record, or doesn't have immediate access to E-85, E-85 is a no brainer for those looking to make big power at a very reasonable price.
Originally Posted by ChefJ,Mar 12 2009, 10:02 PM
You need more e-85 to burn then regular petrol though. Which is why most if not all people running e85 on high boost platforms upgrade the entire fuel system setup.
Most guys dont usually take the second route, but its always an option.
Originally Posted by ScorpionT,Mar 12 2009, 11:09 PM
There are some exceptions. You can make 400whp a couple different ways. You can up the boost which requires more air, or you can bump the compression ratio which requires higher octane. If you up the compression ratio, you could boost less and still make 400whp, and you would also save fuel.
Originally Posted by Peter@ISP,Mar 12 2009, 01:01 PM
i was asking same question after we tuned it.
