Problems with Greddy kit?
Old Oct 22, 2007 | 05:00 PM
  #21
S2Kart's Avatar
Originally Posted by s2kpnoy,Oct 22 2007, 02:29 PM
my greddy install went exactly like yours did, one of the hoses was to short and had to buy 2 feet of that. btw, which spark plugs did you go with?
NGK copper, 1 step colder. I want to get the NGK Iridium 1 step colder - does anyone know the part no?
Old Oct 22, 2007 | 05:13 PM
  #22
brilliant's Avatar
i would like to know the part # for the ngk iridium as well
Old Oct 23, 2007 | 08:17 PM
  #23
brilliant's Avatar
Originally Posted by myblaks2k,Oct 22 2007, 04:32 PM
^ do you have the phone/ website to invision and xs-engineeing?
Invision is a site sponsor, should be no problem finding their #, and XS's number is 714.554.7474 ask for Troy. I wouldn't call till after SEMA though b/c they are very busy right now. Also, wait and see if I have any problems with my install b4 you take your car there. So far I don't like their customer service.
I am picking up my car at noon tomorrow. Will post details tomorrow.
Also, what plugs are you guys running? Part #'s?
how bout these? http://www.ngk.com/results_app.asp?AAIA=1430227
Old Oct 24, 2007 | 06:00 AM
  #24
s2kpnoy's Avatar
I would also like a part number on what spark plugs you guys are using also
Old Oct 24, 2007 | 09:08 AM
  #25
parkerdw's Avatar
I have the greddy turbo with the included emanage ultimate, and I'm very disappointed with the way my car is behaving once I hit vtec or go WOT suddenly. If I slowly roll into the throttle its not so bad, but any hard acceleration will cause the car to sputter and even backfire. It still makes the topend power I expect, but its a very, very jerky ride getting there. The crazy curve I see on the dyno is pretty much what I feel when getting on it hard. My tuner blames the emanage, and says he doesn't think its safe to try and take any more gas out of the higher rev ranges. I have seen several dyno charts of otherwise stock S2Ks running the greddy and their curves are so much smoother than mine. All else being equal, I 'think" there is something up with my emanage or the harness, but it will be a few days before I can get it checked out.
I was at summit point on Monday, and the car exhibited all the symptoms I have encountered on the street. For the second time, under WOT in 3rd gear all power vanished and the check engine light came on and a large cloud of white smoke came out of my exhaust for about 30 seconds. I pulled it off the track and it promptly stalled. I waited a minute and it restarted with no problem. No CEL and no smoke. It was like I had imagined the whole shutoff incident. The car then ran like 'normal', meaning lots of sputtering, jerking and backfire until my 4th session on the track. It was then a huge gout of flame was seen coming from my left exhaust tip. Right after that, I got up to 5 bars on the temp gauge, and lost half of my horsepower as the car went into safe mode. Since I was now being nearly run over on the track, I called it a day and pulled off into the pits. The car almost immediately cooled down and the power came back.
I have been keeping it under vtec and have been babying the throttle for the last 2 days until I can figure out what the heck is wrong with my setup. I called Greddy and they asked me to make sure the sticker on my ultimate says AP1 and not AP2. It was an AP1 sticker. He then told me that I "might" have an AP2 harness on there but I don't know how to check it myself, so I'm going to take it back to the tuner this week and try to get him and the greddy tech on the same page. I also intend to call them back shortly and have them talk me through the harness check.
My car is totally stock except for the exhaust and gears. Its an Ultimate Racing Dual catback and I also have their matching CAT. I still have the stock spark plugs, but Greddy and my tuner don't think that alone would cause all the vtec/WOT craziness I have been getting. Below VTEC, everything is smooth and the car runs like a champ. You would never know anything is wrong until you stomp the throttle suddenly. The car makes more hp below vtec than it did at WOT before I put the turbo on, so its quite drivable wihout using vtec, but that's not what I paid for.
Any ideas or opinions would be welcome.
Old Oct 24, 2007 | 09:19 AM
  #26
woo's Avatar
woo
hey brilliant,any updates? My friend was sent an ap1 ecu for his ap2 and his injectors/fuel pumps were missing too. Btw I decided I'm gonna go ahead with a 3mm headgasket from inlinepro, wastegate flap bore, 12+ psi boost, and emanage dyno tune. I wanna see what this kit can do. I'll let you know what happens.
Old Oct 24, 2007 | 09:55 AM
  #27
brainwo's Avatar
parkerdw:
Did you install the map sensor as the way greddy told you to?
Did you/tuner data log? Boost/vac leak?
Do you have the stock map from greddy?
Make sure your TPS output from Emanage are setup correctly and map sensor install correctly + boost limiter cut
2.85v across boost liimiter
Analog output setting
Input -Output
0 - 0
0.8 - 0.8
1.34 - 1.34
1.36 - 4.0
1.7 - 4.0
2.0 - 4.0
2.3-4.0 -> 4.0
4.1 - 4.1
4.4 - 4.4
4.7 - 4.7
5.0 - 5.0v
Old Oct 24, 2007 | 10:52 AM
  #28
VAD's Avatar
VAD
Your spark plug is buried deep within the following post:
https://www.s2ki.com/forums/index.php?showt...0&#entry9655960
Old Oct 24, 2007 | 12:19 PM
  #29
S2Kart's Avatar
Good info, thanks.
-Doug
Old Oct 24, 2007 | 01:40 PM
  #30
-DOZER-'s Avatar
Is there anyone who installed this kit and has not had problems?
