PTUNING S2000 Turbo System (Pics, Dyno, Pricing)
Is it possible to run 2 (or more) differen't maps with this kit and say...Flashpro? One map for low boost or wastegate pressure and then one for normal or higher boost? Is this possible or would it be too much of a hassle?
Why not run an electronic boost controller that has programmable boost settings in it? Then you can crank the boost up on the fly without have to stop the car and flash it.
How about if you needed like a valet mode type thing, in case you bring your car to a shop or something and want to put a rev limiter at like 3000rpm or something? Would that be possible?
Originally Posted by robotvoice' timestamp='1343686288' post='21900237
[quote name='NeedanS2KNOW' timestamp='1343680734' post='21899985']
[/quote]
I don't know enough about tuning s2k's to say if it would be safe or not but I would think it would be ok as long as your main tune for your max boost is safe (someone from PTuning like Toan or Andrew would have to chime in on this). I could be wrong though..it might all depend on your engine management solution/wastegate setup/target boost and a/f ratios, etc. and might not be possible or practical. I never looked into it that much honestly. I always used my right foot as boost control
But I can see that it would be cool to be able to limit boost on the fly.I think the Flashpro will let you flash a valet mode map too. Can't remember if it was pre-loaded on the unit or not though.
Originally Posted by NeedanS2KNOW' timestamp='1343698601' post='21900690
[quote name='robotvoice' timestamp='1343686288' post='21900237']
[/quote]
[/quote]
Hmmm interesting... I was just curious and thought I'd ask. Thanks for your input.
