PTUNING S2000 Turbo System (Pics, Dyno, Pricing)
From: The land of corruption, cachaça, and caipirinhas.
After knowing Daryl for a couple years (bought his old exhaust), I finally got a ride in his car a couple weekends back, as well as a bit of driver's seat time.
All I can say is wow. Once I pay off the S and can pick up a daily driver, all my pennies will be saved for one of these kits!
It was very much
with those tires! hahaha
Thank you. So weird how the shop that tuned my car recommended 16psi, yet nobody else does lol.
Originally Posted by sata3000' timestamp='1350398619' post='22085884
Ya most people wouldnt say 16 psi on 93 oct...
Can I assume the way to overcome is e85 or meth inj ? If yes, what's the limitations on psi with those ?
Gracias for the knowledge !
The limitation is detonation. An increased in cylinder pressure (boost) will increase the chance of detonation. http://www.enginelogics.com/detonation.html
Here's a series of log at 15psi on 91octane, Ptuning GTX3076R. Notice the difference in ignition timing vs. knock. Knock = detonation.
The goal is to achieve optimal ignition timing with no detonation at a given boost pressure.
The last graph is at 13psi with ignition timing of 12.
Most tuners will tune to the safest ignition advance and boost.
Currently I'm at 16-17psi on 91oct... based on many hours of street tuning and risk taking....
Retarding the ignition advance to run a set target boost will increase exhaust temps..to the point of melting valves...that's another limitation in itself.
Originally Posted by OHclassic' timestamp='1350423040' post='22087226
[quote name='sata3000' timestamp='1350398619' post='22085884']
[/quote]
Thanks, great explanation assuming it's correct as I'm no expert, just looking for insight as to what's going on.
* I asked a some other questions that I'll repeat as maybe you didn't see..
Can I assume the way to overcome (the octane/detonation issue) is e85 or meth inj ? If yes, what's the limitations on psi with those ?
* New question - Why does the alcohol overcome the octane and detonation problem ? Does it detonate at a higher temp and/or pressure than gas ?
Thanks !
