PTuning Scavenging Pump?
^ that's what did to my old civic too! I was thinking doing the same in the s2 just not sure since I never could figure out how to get rid of that air bag light was annoying.
Sent from my SPH-L710 using Tapatalk 2
If I have time, I'll post a DIY wire tuck (labeling each connector/etc). I'm quite familiar with the (factory) harness. I have just never used a relay to feed a second relay; just seems weird (and likely superfluous). Which wideband do you have that it necessitates using a solenoid? For what it's worth, to move the fusebox into the passenger foot well (beneath the heater core) you only need to lengthen 7 (small gauge) wires.
Had to extend the 12-14 wires to the center of the esp unit the way i routed it. Then running the remainder of the factory harness on the outside of the fender so you have to extend the factory headlight grounds, abs orange wires, horn, ac, and 2 big pain in the ass thick red and green power steering wires. no worries though... I almost gave up and am just going to pay this honda wiring guru to finsh what I started... worst part was the car was perfectly fine before I messed with it! Battery relocation turned into full out wire tuck chaos lol
So in total:
Fuse box--7 wires (all small gauge)
EPS--5 wires (2 8 gauge (red, green) and 3 small gauge (I use 18 gauge))
Do your headlights work? What about your emergency lights?
So in total:
What im thinking is map got deleted off the ECU somehow when i was playing on aem tuner possibly... and new battery is just not strong enought/bad grounds to fire it up on the stock ecu now hence spark, fuel, but wont start now.... IF there was any enthusiests around connecticut i would be forever grateful and buy them mad pizza and beer for the day if they could come help...
Humm Im away on work.. Wish I would be right in front of it to remember what I did exactly. I never got that far to even try the headlights... car wont start... so never tried. Where did you put the bundle of grounds. the ones that were normaly on the inside front by the pass. headlight. Pretty much the transpiring events that happened with my tuck were and still are this. Relocated all that stuff... battery was dead... jumping... charging... still not starting... got a new battery... cranking cranking cranking... test spark... no spark via AEM... plug in stock ecu... car fire right up and idles... aem back in... no spark... send ecu to aem... its fine. put stock ecu back in... not starting with the stock ecu... gets spark but seems weak.
