puddymod vs inlinepro diff kit
Old Aug 26, 2009 | 04:44 PM
s2mmkay's Avatar
Default puddymod vs inlinepro diff kit
tried searching and maybe i put the wrong tags, but since i have aquired most of my turbo parts and willbe installing and tuning it shortly.. i was wondering about my rear diff options
theres the puddymod diff which i've heard is pretty strong but i havent really seen any high HP setups running it. also its more expensive than the IP kit.
then theres the inline pro kit which i've seen/read about low 10's and high 9's being run with it.
plz chime in with any other options i may have and the $$ involved.
again, sorry if its been covered before but my search didnt show any results.
edit: sorry typo.. no disrespect puddy.
Old Aug 26, 2009 | 04:58 PM
JoeyBalls's Avatar
did I just read that right? "pussymod" diff, hahah I haven't heard that, origin?
Old Aug 26, 2009 | 05:01 PM
Spooky AP2's Avatar
https://www.s2ki.com/forums/index.ph...f=142&t=643043
Here's a good thread about rear end builds.
I have a Puddymod setup and I'm really happy with it so far. Ben is a great guy and does really good work. I would highly recommend getting a diff kit from him.
Old Aug 26, 2009 | 05:03 PM
rosscoe21's Avatar
pussymod HAHAHA!!!!!!! I think you might want to edit your post.
jwa4378's Avatar
The PuddyMod and R32 conversions are really the only options...
phils2k is running the PuddyMod rear end, and was making ~620rwhp. I am pretty sure it can handle whatever you throw at it. The R32 (InlinePro) conversion kit is tougher to install, and requires new axles. The PuddyMod rear end is pretty much plug-n-play (although the axles are on borrowed time at that power level anyway).
John
Old Aug 26, 2009 | 05:07 PM
s2mmkay's Avatar
[QUOTE=jwa4378,Aug 26 2009, 09:03 PM] The PuddyMod and R32 conversions are really the only options...
Old Aug 26, 2009 | 05:20 PM
DeadZero's Avatar
Puddymod also has different staged options. and all he needs is your stock diff. Inlinepro you would have to buy your own R32 diff and then have them build it from the only option they have.
Old Aug 26, 2009 | 06:25 PM
vtfo0lio's Avatar
I like the Puddymod diff. I'd bet its plenty strong unless you want to set records. Anyhow, you can just go get the bolt on axels and driveshafts from the DriveShaft shop. They're expensive as hell though. At least 1800 on top of the puddy kit.
Old Aug 26, 2009 | 06:39 PM
juntuned's Avatar
I vote for ben. (puddy)... always given genuine advice whenever I have asked.
Tell him what you need and Im sure he can make it.
Old Aug 26, 2009 | 06:40 PM
ERL_S2000's Avatar
Its all in how you drive the car.
