Pushing limits of 600cc and OEM MAP? Is 13psi achiveable?
Old Aug 12, 2013 | 08:48 AM
s2000Junky's Avatar
You are going to see closer to 13psi at ap2 redline with a 3" so keep that in mind. SOS isnt very accurate on their website. What size pulley you running now? I would be concerned that your 600cc injectors wont deliver the fuel you will need to cover a 3 pulley. You may be able to cheat with upping the fuel pressure but you really are pushing it, not sure that will even do it. I would go with a 3.4" or 3.2" max. I would also pick up a greddy pressure sensor and run that instead. You will get a better tune.
Old Aug 12, 2013 | 10:25 AM
EOE's Avatar
EOE
Hey junky, I am at 3.4" and I Hit 9psi right on the nose, could very well be 10Psi if I hit fuel cut.
I am at exactly 80% Duty Cycle already, I know I know.
I just don't want a complete retune.
Old Aug 13, 2013 | 02:54 PM
kraft's Avatar
YES you can
Old Aug 22, 2013 | 03:06 PM
EOE's Avatar
EOE
One more questions, Running Greddy pressure sensor in conjunction with OEM sensor and cap out the voltage of OEM senseo at 28.v? Did I understand that correctly?
Old Dec 23, 2013 | 10:39 AM
EOE's Avatar
EOE
I ended up doing the following:
- SOS NOVI1000 3.2" Pulley
- Achieved 11PSI right on the dot.
- Stock MAP sensor held up just fine
- Injector Duty Cycle is at 87-89%
- Belt slip was an issue and it had to be he-man like tightened.
- Tune is conservative.
Final Numbers were 350HP and 230TQ
Old Dec 23, 2013 | 11:34 AM
CoolGuy094's Avatar
Awesome man. What kind of dyno were you on?
Old Dec 23, 2013 | 11:52 AM
EOE's Avatar
EOE
Thank man. DynoJet
The 3.4" to 3.2" pulley upgrade yield some nice gains btw. The car loved it. 3.2" gave nice boost across the whole power band. 6K+ obviously is when she moves out.
Here is 7psi to 9psi bump DYNO, so until I get the new DYNO printout use your imagination guys to picture power bump across the power-band.
Old Dec 24, 2013 | 07:36 AM
camuman's Avatar
Personally I would change out the map sensor and up the injectors. But yes it can be done. Nice Dyno for lower boost especially with sae correction.
neptuner
Mar 15, 2018 03:56 PM
Disgustipated
Jun 21, 2017 02:19 PM
seansniper
Oct 3, 2012 11:56 PM
2QYK4U
Jul 2, 2007 06:13 PM
Sideways
Oct 8, 2004 09:03 AM
