car not starting with sos 3bar map
Old Oct 3, 2012 | 10:01 AM
seansniper's Avatar
Default car not starting with sos 3bar map
My car will start fine with the stock map sensor, how ever the boost will limit at like .5 psi, if I do a boost leak test it holds boost fine, So I swap it out with my SOS 3 bar map sensor and change the settings in the aem ecu to what SOS recommends on their website. Upon doing that, the car tries to turn over starts for maybe a second or less and dies.
Is there anything I have to change in the aem ecu? I am running the base s2000 map, I have the injectors changed and the map sensor changed. And I can only get it to run on the stock map sensor. Maybe I have a faulty SOS sensor? Also I thought the stock sensor was supposed to read boost to maybe 10 psi? Or is there a setting that I have to adjust in the aem ecu to allow the car to see boost past 0 psi?
Any help would be great, I currently do not have a boost controller/ solenoid and am running a tial 38mm wastegate with a 8psi spring
Old Oct 3, 2012 | 11:56 PM
s2knoob89's Avatar
You have to change the break points and retune the fuel and ignition map after changing to the 3bar map sensor.
bobonacus
Jul 27, 2011 11:02 PM
Cody Strife
Jun 16, 2011 09:41 AM
2QYK4U
Jul 2, 2007 06:13 PM
C45P312
Jul 4, 2006 10:04 AM
Sideways
Oct 8, 2004 09:03 AM
