Question about base MAP's
Old May 16, 2007 | 07:50 AM
ChefJ's Avatar
Default Question about base MAP's
I have 3 base maps for different setups and psi's
I think they are all for 650cc injectors and the emanage.
My question is when I bring them up on the greddy emanage software what kind of numbers and on what screens should I be looking for?? I may need to adjust some things on there and would just like to knw what the important ones are. TIA..
Old May 16, 2007 | 08:26 AM
CIVICTOS2000's Avatar
IMO all number are important....you should be looking at all of them...
D.
Old May 16, 2007 | 09:49 AM
ChefJ's Avatar
I know that I am talking about in the charts i.e.
Airflow adjustment MAP
BC
VTEC
Additionsal injection MAP
Ignition timing adjustment MAP
What numbers should I be looking for as a Base MAp to go to the tuner?
Old May 16, 2007 | 10:06 AM
BlownAP's Avatar
tune everything off map first of all, i know it will give you an option for TPS or RPM.
after that you should be looking at Ign map and Injct. maps
Old May 16, 2007 | 10:21 AM
ChefJ's Avatar
I can't find map in the software. I have 3 basemaps and can't really figure out which one to use to start with.
Old May 16, 2007 | 01:52 PM
BlownAP's Avatar
[QUOTE=ChefJ,May 16 2007, 10:21 AM] I can't find map in the software.
Old May 16, 2007 | 02:07 PM
ChefJ's Avatar
Originally Posted by BlownAP,May 16 2007, 01:52 PM
what i meant by map Kpa, sounds like you should just get it towed to a turner, before something blows...
it is really the best thing if you do not have a solid basemap or tuning knowledge, its not worth the risk.
Absolute pressure (kpa)
700 1500 2100 2700 3300 3900 etc....
68 0.0 5.0 10.0 10.0 10.0 10.0
75 0.0 5.0 10.0 10.0 10.0 10.0
82 0.0 10.0 10.0 10.0 10.0 10.0
90 0.0 20.0 30.0 30.0 30.0 30.0
97 0.0 20.0 30.0 30.0 30.0 30.0
105 0.0 30.0 30.0 30.0 37.0 37.0
I have the whole chart and my installer hasn't seen any of it yet but I am sure he knows much more about it then I do. I just want to know if this is fairly accurate.
Old May 16, 2007 | 02:15 PM
BlownAP's Avatar
[QUOTE=ChefJ,May 16 2007, 02:07 PM] Absolute pressure (kpa)
Old May 16, 2007 | 02:26 PM
ChefJ's Avatar
Its the additional injection MAP (kpa)
rpm 100 increment (kpa) 1 increment adjustment value (%) .5
I have a greddy pressure sensor.
Its a basemap I have from a Greddy setup with 13 psi and 650 cc injectors
I have 650 cc injectors an inline setup and just need to get it about 30 miles.
Old May 16, 2007 | 02:29 PM
BlownAP's Avatar
ok so they are for the same size injectors, that is good. as long as the car starts you might want to give it a little more fuel just to be on the safe side, and try not to boost......
lvd1102
May 28, 2010 05:06 PM
mr_grand_prix
Dec 6, 2007 01:01 PM
Dsgs2k3
Mar 12, 2007 01:25 PM
Reignman
Jul 31, 2003 11:52 PM
Reignman
Jul 29, 2003 08:11 PM
