question about fuel pump rewire
Old Jul 19, 2015 | 12:15 PM
umair's Avatar
Default question about fuel pump rewire
Because of my turbo kit i had to redo a ton of wires by the fuse box because they melted together. I redid all of them today but now my fuel pump wont prime. When i give it power manually it works. My question is that if you do a rewire does the ecu no longer control when the pump gets power? Im asking because my power source for the pump is directly from the battery. I dont hear the relay click either but it looks good. Im just trying to see where i should start.
Thanks
Old Jul 19, 2015 | 01:56 PM
umair's Avatar
I have a feeling that the aem ems might have gone bad.
Old Jul 19, 2015 | 02:54 PM
5thgen's Avatar
Did you rewire (run a relay) to the pump?
Or did you rewire the melted wires?
Old Jul 19, 2015 | 03:08 PM
braeden's Avatar
The relay is an electro-mechanical switch. The fuel pump is actuated through the relay, and the relay is actuated by the stock 12V fuel pump wire.
Old Jul 19, 2015 | 06:05 PM
umair's Avatar
Turned out that i blew about 8 fuses. Problem fixed
myjdmproject
Sep 21, 2015 06:36 AM
Dize
Apr 10, 2014 06:25 AM
GDM S2K
Jan 8, 2007 08:48 AM
tetsuo73
Mar 22, 2005 05:30 PM
