fuel pump issue please help
Old Jan 7, 2007 | 04:19 PM
GDM S2K's Avatar
Default fuel pump issue please help
Hears my situation i just put my motor back in the car and wanted to test my fuel pump to make sure it was priming. well it didnt. I checked the fuse under the dash and it was fine. I pulled the pump out thinking maybe a bad pump or bad wiring nope not it. the floater still get power but it seems the pump does not can anyone give me a lil hand in this please....
also I swaped the factory ecu in to see if it was a prob with my AEM EMS and it still didnt turn on, could it be a facotry fuel cut off switch somewhere in the car?
Old Jan 7, 2007 | 08:31 PM
Kwando's Avatar
check all your fuses... also check the 15amp ACG fuse... i had a similar problem where the fuel pump only primed when i attempted to start the car and it was the ACG fuse.
Old Jan 7, 2007 | 09:39 PM
jzz30's Avatar
relay?
Old Jan 8, 2007 | 03:56 AM
GDM S2K's Avatar
its not even priming
Old Jan 8, 2007 | 08:48 AM
GDM S2K's Avatar
ok checked all the fuses again checked the relay all seems good, even checked the wiring on the pump. so im lost at this point
joefish1298
Mar 30, 2021 12:55 AM
myjdmproject
Sep 21, 2015 06:36 AM
umair
Jul 19, 2015 06:05 PM
LordSovereign
May 27, 2015 12:30 PM
JToolz
Nov 6, 2006 09:48 AM
