Question regarding Map sensor and EMU
Old Apr 12, 2010 | 04:29 PM
skool u's Avatar
Default Question regarding Map sensor and EMU
Just a quick question about map sensors and EMU. If I have been tuned on EMU and swap out the Map sensor for a hondata4 bar one, will the EMU still respond the same or will I have to make any recalibrations to the unit?
Old Apr 12, 2010 | 05:35 PM
SpaS2K2005's Avatar
you will have to recalibrate the EMU for the new sensor. if you have an AEM its easy to do. you just have to select the MAP you have now in the options and youre good. they have a bunch pre calibrated.
Old Apr 12, 2010 | 06:26 PM
skool u's Avatar
Essentially my position is this. I am currenntly running the EMU with the stock map sensor. My wastegate is set to about 5.5 psi. It is not fully tuned and I am heading to the dyno this weekend.
I have an EMS waiting to be installed when I get there (I had it installed but couldn't get it to idle properly so I'm waiting or the tuner to do it!) and I have just ordered a hondata 4 bar map sensor.
I'm assuming the easiest way to have this all installed is to do the following:
drive to the tuner with my current Greddy Emanage Ultimate setup
get on the dyno
remove EMU and install EMS and hondata map sensor
Tune
does this sound like a logical plan of attack?
amdaman
May 20, 2015 01:35 AM
Prokaw875
Oct 1, 2012 02:29 PM
2QYK4U
Jul 2, 2007 06:13 PM
evf2000
Jan 23, 2006 02:42 PM
