Questions about Turbo Build
Old Jun 3, 2009 | 10:11 AM
ryoga4523's Avatar
Default Questions about Turbo Build
I recently obtained this kit (minus the AEM, had to go Kpro because of DBW)
https://www.s2ki.com/forums/index.php?showtopic=699582
and was wondering if I should look into any other cooling mods? Also, is getting a 3mm hg the best way to go if I am looking to drive this daily?
Old Jun 3, 2009 | 10:19 AM
MADjdm's Avatar
get a 3mm if you want more than mid 300's
Old Jun 3, 2009 | 10:26 AM
siadam's Avatar
H/G ISN'T needed.
Old Jun 3, 2009 | 10:32 AM
MADjdm's Avatar
Originally Posted by siadam,Jun 3 2009, 10:26 AM
H/G ISN'T needed.
I am 100% against using a thicker HG
But in the case of using an IP Log, I believe it's your only option to make power above 400 in a somewhat safe manner
As the OP did not specify his power goals, its neither here nor there
Old Jun 3, 2009 | 10:47 AM
ryoga4523's Avatar
I was looking to make it as DD as possible, so my goals were around 300-375 to the wheels. I am hoping with that set up, I will not need to get a hg, but if it will make the car more reliable and have a longer life, then I will do it.
Old Jun 3, 2009 | 10:51 AM
MADjdm's Avatar
Use OEM
Old Jun 3, 2009 | 11:52 AM
AndyFloyd's Avatar
OEM HG, 10psi, 370whp = fun s2k
Old Jun 3, 2009 | 02:53 PM
ryoga4523's Avatar
Do you have any more factual information that I can take to the tuning shop to show them that the stock HG can handle 10 psi? Cause I do not think that they will do more than 8 psi on a stock HG. Thanks for all of your information and help.
Has anyone done any cooling mods with a turbo set up? Like fan switch, or thermometer, or samco hoses, or new radiator? Do they make a difference, or are they just for safety precautions?
Old Jun 3, 2009 | 03:36 PM
AndyFloyd's Avatar
yea the fact that i run 11psi on pump every day.
Old Jun 3, 2009 | 03:46 PM
RangOs2000's Avatar
yah i run 16psi with meth on the stock hg, you can tell them to call my shop. Let me know ill give you the info
RXM9600
Jan 23, 2014 09:06 AM
Ek_Jak
May 17, 2010 07:33 PM
saxtonsS2k
Dec 30, 2008 08:53 AM
StatixNWH
Feb 6, 2007 08:10 PM
nrgetik
Sep 13, 2006 10:40 PM
