Quick Fuel Pump Question
Old Dec 19, 2006 | 06:03 AM
JDM S2000's Avatar
Banned
Default Quick Fuel Pump Question
Does the ECU need to be in for my fuel pump to run?
I really wanted to see if the fuel pump was working while I wait for my ecu to get here. So I pulled the fuel line off and turned the ignition forward.
Now on most cars you would be able to hear the pump running at that point, but I did not hear it running, nor did gas come out of the fuel line.
Im hoping the answer is yes and I just need to plug the ecu in. Otherwise something is wrong with my fuel pump install.
TIA
Old Dec 19, 2006 | 08:33 AM
GDM S2K's Avatar
Yes u need toe ecu in to tell it to turn on
Old Dec 19, 2006 | 10:21 AM
AssassinJN's Avatar
If you didn't need the ecu then the fuel pump would just continue to pump gas whether the engine wanted/needed it or not... That would be bad!
Old Dec 19, 2006 | 10:32 AM
Phillie's Avatar
True or you can hook power up to it just to test it.
Old Dec 19, 2006 | 10:41 AM
JDM S2000's Avatar
Banned
Not necessarily because as soon as you turn your key to ignition the pump starts priming.
Old Dec 19, 2006 | 10:46 AM
Dsgs2k3's Avatar
the fuel pump should come with a clip with a power and ground wire that come out of it. plug it in then hook it up to a battery and stick it into gasoline tub and see if it works
Old Dec 19, 2006 | 10:48 AM
JDM S2000's Avatar
Banned
The pump has been in the tank for quite sometime now.
I hooked it up to the factory harness and did not use the clip with the red and black wire.
Old Dec 20, 2006 | 06:51 PM
JDM S2000's Avatar
Banned
found the problem, its been so long since ive drive the S, I forgot to push the clutch in.
s2000Junky
Dec 10, 2024 02:16 PM
RAIN H8R
Feb 22, 2024 07:42 AM
TonysMI4
Aug 29, 2011 10:10 AM
rbreland
Oct 6, 2001 03:38 AM
Andre
Feb 26, 2001 07:09 PM
