Quick Question about EGT's
Old Nov 14, 2010 | 05:25 PM
JoeyBalls's Avatar
Thumbs up Quick Question about EGT's
So I have the EGT probe located about an inch post Turbo, I did not want to put a whole in my manifold for warranty reasons.
Usually WOT in low boost I see 1100-1200 WOT with AFR's high 11's to 12.0 leanest.
Last night while I was blowing by a Roush mustang in high boost (20lbs) in 5th gear (I basically did a pull from 5th gear about 5,000RPMS to redline, I saw EGTs of 1200-1250 but when I let off the gas I saw 1450F then as soon as I got back on the gas to for normal driving it immediatly started to go back down
This normal?
Old Nov 14, 2010 | 07:14 PM
siadam's Avatar
This normal?
Think about what happens when you lift off the throttle in regards to your afr's and that should answer your question.
Old Nov 14, 2010 | 10:48 PM
A51_AP1's Avatar
Yes it's normal. Remember that fuels like gasoline and ethanol also cool engine blocks and components. This applies to pistons as well; the incoming flow of fuel allows the piston to cool off and keep EGT's down
Old Nov 14, 2010 | 11:35 PM
EternalLx's Avatar
Old Nov 15, 2010 | 12:26 AM
JoeyBalls's Avatar
makes sense!, as always, thanks guys
Old Nov 15, 2010 | 01:02 AM
Blucky87's Avatar
would 1100-1250 WOT be the norm for EGTs in each runner of my manifold preturbo?
That Guy 1987
May 22, 2014 10:42 AM
DFWs2k
Jun 14, 2010 11:53 AM
2QYK4U
Jan 10, 2007 05:37 PM
timg
Aug 23, 2006 01:53 PM
BAD 97 WS-6
Apr 19, 2002 05:33 AM
