quick question about turbos
Old Feb 3, 2011 | 12:27 PM
AusS2000's Avatar
Oh, and turbos consist of three main sections; turbine, CHRA (Center Housing Rotating Assembly), and Compressor.
During installation all three parts rotate against each other to allow for fitment but should be securely tightened before running. The turbine position is set by the exhaust manifold. The CHRA should have the oil feed at the top and the drain at the bottom. Some water cooled CHRAs should also be mounted at an angle for water flow apparently. And the compressor should be mounted so it's output is in a suitable direction for the charge piping.
Make sure the bolts securing the CHRA to the turbine and compressor are tight. I had some problems with this that cost me two turbos. I use Nord-Lock washers now to keep mine tight.
Old Feb 3, 2011 | 02:26 PM
ap1tuner's Avatar
Wow! Thanks! Everything I needed! And thanks for the proper flaming. Lol. O while I'm thinking of it, has anyone used the website USEDTURBOS.NET? Jw. I have been looking at the stuff they have in stock. They have new, used, and rebuilt turbos and I'm looking at one.
afwfjustin
Jun 28, 2007 03:37 PM
demitri
Jun 4, 2007 02:11 PM
5thelement
Jul 28, 2006 01:29 PM
firefighter81
Aug 21, 2005 07:22 PM
