Random firing when engine is not running
Old May 20, 2010 | 06:35 PM
  #21
Spoolin's Avatar
I've never had this happen in the 5 years I've had the AEM EMS. This is weird and what setting on the AEM would cause this? Maybe something is set up wrong.
Old May 20, 2010 | 06:53 PM
  #22
Suzuka_Joe's Avatar
i've had this too. rarely tho
Old May 20, 2010 | 07:08 PM
  #23
s2000isu's Avatar
mine does once maybe every 30 startups or so.
Old May 20, 2010 | 07:10 PM
  #24
joes sled 2000's Avatar
Honestly it does not even faze me . I think its just a normal ems issue if you want to call it that .
Old May 20, 2010 | 08:44 PM
  #25
jb34304's Avatar
I had e-manage blue... Maybe there was pressure in the crankcase?
Old May 20, 2010 | 08:56 PM
  #26
s2000Junky's Avatar
Originally Posted by Mistman,May 20 2010, 09:00 AM
I've had it backfire and blow off vacuum hoses on a hot start. Worse yet, and not many will actually believe this (I did post a thread the day it happened). I had it backfire once on a hot start and then run backwards. I was at a light and killed it (stupid Iron man clutch) when trying to restart it popped and sorta made a buzzing sound and then started running, didn't sound right but I needed to get out of the intersection, I let the clutch out and the car started backing up. I killed it imediately, jumped out and told the folks behind me to go around, I figured it was messed up. Got in and restarted it and it ran fine, though it was idling high due to a popped vacuum hose. I called my tuner as soon as I got into work and he said he'd never heard of it before except in a diesel. I've had 2 stroke dirt bikes catch wrong and run backward but I didn't think a modern engine could do it w/out messing stufff up. I't been fine since. I think it's a little rich on a hot start and need to get it adjusted.
Wow I have never heard of that before. That's craziness, I didn't even think that was possible
Old May 21, 2010 | 06:05 AM
  #27
siadam's Avatar
ID's here.
I've not experienced this.
Old May 21, 2010 | 07:24 AM
  #28
Spooky AP2's Avatar
Same here. Mine started doing this after I switched to ID 1000s. Seems to happen more often when its hot and humid out, but that may not be related.
Old May 21, 2010 | 07:31 AM
  #29
Sideways's Avatar
RC's here. Both peak and hold and the saturated variety have caused these symptoms.
Old May 21, 2010 | 09:17 AM
  #30
Irishflame27's Avatar
my AEM did this also, every now and again when i would cycle the key to prime the pump, i would get a loud, "FROOMP" sound from the engine, kinda embarassing lol good thing im Kpro bround now.....
