rc injector clips?
Old Nov 8, 2005 | 05:15 AM
rick bailey's Avatar
Default rc injector clips?
im looking on the net and some places say the s2000 needs spacers for 750cc injectors? is this true or do i just need the clips and im good to go?
Old Nov 8, 2005 | 05:44 AM
Sideways's Avatar
They come with 0.2 inch spacers. I ended up using washers to do the job at about half that much space. The spacers are just pieces of tubing. They are intended to go under the posts and do not allow enough room to tighten the rail down if used on top.
The reason for spacing the rail is apparent in this photo:
Old Nov 8, 2005 | 06:13 AM
slamar1's Avatar
I went to Home Depot and bought a small bag of washers. You want the rail snug, but not too tight.
Old Nov 8, 2005 | 09:09 AM
ideugene's Avatar
M8 is the size!
Old Nov 8, 2005 | 09:18 AM
AROD's Avatar
i have the honda part number to buy the right studs for aftermarket injectors so you dn't have to use washers
Old Nov 8, 2005 | 11:38 AM
Sideways's Avatar
Would you consider sharing?
Old Nov 8, 2005 | 12:49 PM
yeah but if there over 5 bucks ill just use washers
Old Nov 8, 2005 | 02:09 PM
John_Z's Avatar
If you're at Home Depot might as well pick up the replacement O-rings that go between the injector body and intake mani just to have on hand.
Old Nov 8, 2005 | 10:07 PM
NewbieS2K's Avatar
I keep hearing about upgrading injectors. Can someone explain to me why, cant RC "bore" out the stock injectors? That way it will be an exact fit. I'm sure only to a certain extent but, wouldnt that be cheaper? Is it more of a switch of low to high impedance/peak hold?
Thanks,
Andrew
Old Nov 9, 2005 | 06:15 AM
NewbieS2K's Avatar
...correct me if im in the wrong section asking this or if the answer is somewhere else.
Thanks,
Andrew
