rc injector clips?
Old Nov 9, 2005 | 09:15 AM
AROD's Avatar
Originally Posted by Sideways,Nov 8 2005, 03:38 PM
Would you consider sharing?
sorry it took me so long bro, had to find the package. the part number is
90027-POA-003
they are like 2 bucks each but it makes for a cleaner look
Old Nov 9, 2005 | 10:01 AM
ideugene's Avatar
Do you happen to know where this part comes from? I can't find that particular part number in Majestic Honda.
Old Nov 9, 2005 | 01:21 PM
AusS2000's Avatar
Originally Posted by NewbieS2K,Nov 9 2005, 05:07 PM
Can someone explain to me why, cant RC "bore" out the stock injectors? That way it will be an exact fit. I'm sure only to a certain extent but, wouldnt that be cheaper? Is it more of a switch of low to high impedance/peak hold?
Injectors aren't just tubes that can be bored. They are effectively a valve that can open and flow a certain amount. The stock injectors are too small to be 'upgraded' and even if they could be it would be more expensive than replacing them.
Also, it has nothing to do with changing impedance. Ideally you replace with high impedance like stock. If you swap for low impedance you require additional electronics (a resistor box) to run them.
Shftat9k
Apr 26, 2009 09:44 AM
ChefJ
Jan 15, 2009 04:57 AM
Sideways
Dec 10, 2008 03:46 PM
folex187
Sep 19, 2005 06:52 AM
Asura
Aug 4, 2005 11:50 AM
