Rear End
Old May 13, 2009 | 05:52 PM
  #21
Spec_Ops2087's Avatar
Originally Posted by rob!,May 13 2009, 07:24 PM
im at 550whp on stock diff but i do not launch the car. I dont even go WOT in first gear at all. I really want to get the inline pro diff setup just dont have the funds right now.
1st is useless, though today I went WOT in 1st...it put a smile on my face
Yes you can get the brackets but then the axles will be the next thing to break...the tranny is much stronger then the rear drivetrain
Old May 13, 2009 | 07:31 PM
  #22
TurboCongo's Avatar
I have a fully built trany that i got for a grand... i nearly stole it for that price though. Full cryo... AHAHAHAH I just want the rear to do some quarter mile runs
Old May 13, 2009 | 07:39 PM
  #23
sbrodacz's Avatar
Banned
i wouldnt call a full cryo trans a fully built trans.
Old May 14, 2009 | 07:07 AM
  #24
passmans2kny's Avatar
we need a cheaper rear end solution
Old May 14, 2009 | 08:03 AM
  #25
berlinas2k2's Avatar
Old May 14, 2009 | 09:40 AM
  #26
btstone84's Avatar
PPG is a fully built tranny. I paid WAY more than 1000$
Old May 14, 2009 | 09:46 AM
  #27
AndyFloyd's Avatar
"everything you wish you had"
I wish I had that PPG tranny....lol
Old May 14, 2009 | 11:20 AM
  #28
TurboCongo's Avatar
about time someone said it!
What would you call a built tranny if cryo treated everthing doesnt apply?
Old May 14, 2009 | 12:08 PM
  #29
sbrodacz's Avatar
Banned
they're are cheaper solutions out there, it's just the bracket that is costing so much. For example I can get a cobra 8.8 rear diff for $250, axles would cost between $1200-$1700 depending on which ones I wanted. The Cobra drive shaft can be reused, it would just need to be shorten. The hardest part is getting a bracket.
A ppg setup is a built tranny.
Old May 14, 2009 | 03:44 PM
  #30
PhantomAP1's Avatar
An engineer with access to a CNC machine will be able to position the rear end, measure the requirements for the mounts/brackets, and have them cut from a durable metal blank. The hardest parts to source would be the axles and drieshaft..
On the other hand, I KNOW I don't have the skills to cut the Cobra driveshaft down to size and re-weld it so that it is balanced enough for the revs that our stock shaft sees... Maybe somebody who can pull it off would be willing to spend the time to do it and possibly design a kit that would be cheaper than the IP Kit?
