Rebuild II
Old Oct 29, 2009 | 03:26 AM
AusS2000's Avatar
Default Rebuild II
I thought I would start a thread about my rebuild. My recent trouble with overheating (detonation as a result of bad tuning) encouraged me to get to work on the old block in my garage.
Last weekend I pulled it down and inspected it.
All the pistons had ring damage and most of the cylinders have slight scratching. This damaged was caused by over boosting some 2.5 years ago.
Old Oct 29, 2009 | 03:32 AM
AusS2000's Avatar
The plan involves Woessner low compression pistons. They are 0.5mm oversized and good for about 8.5:1 compression. They will be delivered with the block (and possibly the block guard shown in the third pic) to the machinist.
On the question of sleeves, yes I will use sleeves, the FRM ones already in the block. The machinist will be instructed to bore and hone to the specifications of the pistons. I will also take advice on the blockguard and if applicable it will be installed prior to boring.
The OEM rods have been proven up to and above the sort of power goals I have and so will be retained.
Old Oct 29, 2009 | 03:33 AM
AusS2000's Avatar
Oh, and I will be using ARP head studs, conrod bolts, and header studs.
Old Oct 29, 2009 | 05:56 AM
wadzii's Avatar
Banned
just out of curiosity what does the piston mfr recommend for piston to wall clearance
Old Oct 29, 2009 | 06:25 AM
TRBOKEV's Avatar
Good luck with your build.
I really hope this project works out.
Old Oct 29, 2009 | 11:28 AM
passmans2kny's Avatar
best of luck to ya, whats the power goal?
Old Oct 29, 2009 | 02:04 PM
dsddcd's Avatar
Well the good news is you know why you were having head gasket trouble now.
Good luck, keep up the good pics
Old Oct 29, 2009 | 02:47 PM
AusS2000's Avatar
Not sure of the manufacturer's recommendations yet but will post when I know.
I'm really only gunning for around the same power as now (250kw) and maybe a tad more.
Old Oct 29, 2009 | 05:36 PM
joes sled 2000's Avatar
Nice Aus Its good to see the job done the proper way with no cheesy 3mm headgasket .
Old Oct 29, 2009 | 05:49 PM
AusS2000's Avatar
Without wanting to reopen the argument isn't Rob! running 772hp with a "cheesy 3mm headgasket"?
