rebuild question
Old Nov 6, 2009 | 04:42 AM
solomonster's Avatar
Default rebuild question
i have a question about rebuilding...my motor is starting to get more worn out and i have a spare long block f20(missing a few parts) i was thinking about rebuilding it completely but changing the crank,pistons,rods to a f22 set(which will make my motor a f22 right?) add a 3mm hg and strong studs
my question is should i rebuild it as a f20 or f22 if i want to build my motor for around 350-400hp/200-250tq..at the wheels
2nd part of my question is i have comptech sc on a f20 right now should i just get a aem n call it a day or maybe upgrade to a turbo setup?
3rd part is which motor would be a better candiate to be boosted a f20 or f22?
-thanks (sorry if this is pretty newbie)
Old Nov 6, 2009 | 05:02 AM
kawi10r998cc's Avatar
F22 is better for the build all around. Better torque and power sooner, better spool time, etc. Why would you do a HG though since you're already rebuilding? They aren't as reliable as stock HG and lower compression pistons. THe reason most people run a thicker HG is to avoid rebuilding! Since you're already rebuilding why not go with lower compression pistons and stock HG? Best of both worlds! And as far as turbo vs SC that is really up to you...turbo is more work but way more potential and more fun IMO. I have an AEM EMS 1052U with wideband up for sale right now if you're interested btw...I'm parting out my turbo kit to buy a house here is a link to the for sale page...https://www.s2ki.com/forums/index.ph...f=107&t=741484 if you need anything off it just PM me for a price...good luck with the rebuild!
Old Nov 6, 2009 | 11:51 AM
well i was going to rebuild to stock pretty much change the valve seals and resurface everything...what would i have to do to make a f22 rev up to 9k? i never looked into lower compression pistons and stock hg.. what are the prices on that jus wondering
Old Nov 6, 2009 | 12:02 PM
Prices can vary a lot really depending on parts and who installs it but it won't be too much more than doing it with stock parts (unless you got them free!) you will need to sleeve the block most likely if you go with lower compression pistons, that is where the extra money will come in. I've seen sleeving from $500 to $1200...unless you get FRM compliant pistons, then you won't have to sleeve. And as far as making an F22 rev to 9K, the valvetrain is up to it, the bottom end is not...I believe it's because of the weight of the parts so you'd prob have to rebuild the bottom end anyway to rev to 9K safely. Why worry about revving to 9 anyway? Most high hp builds I've seen the power falls off before than anyway!
Old Nov 6, 2009 | 02:00 PM
Momentum's Avatar
F20 all the way
Old Nov 6, 2009 | 02:50 PM
TRBOKEV's Avatar
DO a leakdown first and see what condition your motor is in before you go and blow your wad on a build.
Old Nov 6, 2009 | 06:40 PM
bluemetals2k's Avatar
the more you drive boost or non boosted the slower your car seems your just getting use to it...park the car for a week or 2 you'll see what I mean
Old Nov 6, 2009 | 09:44 PM
o thanks for the response
yeah well im just going to have a extra long block sitting around so i might as well redo it
lol for some reason i cant even beat a stock cr w/ my comptech ap1 =(
Old Nov 7, 2009 | 12:47 AM
Artisan7471's Avatar
Check this post, for some compression options for your new build.
https://www.s2ki.com/forums/index.ph...ic=732173&st=0
ivory90
Sep 17, 2012 07:34 AM
fadiss2k
Feb 28, 2008 12:29 AM
buzilanga
Mar 13, 2004 06:15 PM
nownor
Mar 7, 2004 07:25 PM
Gioire
Mar 27, 2003 09:01 PM
