Recently installed Modifrys ECT fix
Old Mar 21, 2007 | 03:21 AM
jbotstein1's Avatar
Default Recently installed Modifrys ECT fix
I had this installed a week or so ago, and it seemed to be working fine. Startup showed me with 1 bar, followed by 2 bars after a few minutes of warm-up, then 3 bars during driving w/ occasional 4-5 bars at stop lights and in traffic.
Then a few days back I got to 6 bars! I was sitting in stop n go on the highway when this happened. I pulled off, turned her off, and looked under the hood. Nothing was steaming or boiling. When I turned it back on just a couple minutes later it was back to 3 bars.
Last night I was on the highway and it started going from 3 to 4 then to 5, then I exited the highway and at the stoplight it went 6 bars then to the red square! I pull over and the car seems fine. No steam, no boiling coolant.
I just added a bottle of Redline Water Wetter to my Koyo Radiator. I also have a low temp thermostat and on my EMS my fans are set to come on at 190. What gives? Shouldn't my car be on fire if it is as hot as the gauge says it is? I have done some searching on the site here and I've seen one faulty module, but not many people with big problems. Any solutions? I had thought I ahd done enough cooling stuff to get the car running well. Also, I wasn't even driving hard when the most extreme temp readings occurred.
Thanks
Old Mar 21, 2007 | 03:23 AM
jbotstein1's Avatar
This is the link to the temp page of Modifry. It shows that I was at least 235 degrees if the unit is working proplerly.
http://www.modifry.com/products/ect/ap1.htm
Old Mar 21, 2007 | 01:48 PM
jbotstein1's Avatar
Does anyone have experience with this? I'm scared to drive the car. How do I know if it's working properly?
Old Mar 21, 2007 | 02:44 PM
SOHCmyDOHC's Avatar
Make sure you have good grounds.
Old Mar 21, 2007 | 03:58 PM
geists2k's Avatar
I have this installed as well, but I'm AP2 and we have different gauges.
I also have the *exact same* setup with the Koyo, EMS fan settings, etc. and have never seen my gauge get above the 210 mark.
http://www.modifry.com/products/ect/ap2.htm
I would get in touch with Bob and see what he says. I know the stock AP1 gauge has a ton of averaging in it and with only six bars, there still has to be plenty in there.
Old Mar 21, 2007 | 03:59 PM
geists2k's Avatar
If you have never had any overheating issues in the past and your setup has not changed much, then I would say you need to check the install of the ECT mod.
Old Mar 21, 2007 | 04:19 PM
Kwando's Avatar
i had a similar issue. it was a defective unit. contact modifry.
Old Mar 21, 2007 | 04:20 PM
jbotstein1's Avatar
Thanks guys. I guess I'll call Bob. He only lives about 20 min away
s2000ellier
Apr 29, 2013 06:53 AM
AlX Boi
Dec 29, 2009 08:33 AM
supersulli
Dec 13, 2004 05:21 PM
BBY2KS2K
Dec 22, 2002 11:32 PM
RayN
Jul 3, 2002 12:57 PM
