Removing the oil cooler
I removed the oil cooler to put on the Inline Pro relocation kit and I am wondering if I can remove the hard black pipe that runs from the cooler across the front of the block. I am not sure if the oil cooler feeds from the block to the T stat or if it goes the other way. The last thing I need is to overheat. Any suggestions? Also does anyone know a Honda part number for the oil filter adapter that is needed when the cooler is removed.
I've been looking into 'converting' to an air/oil cooler when I get my turbo on and using those lines specifically for the turbo.
In my searching I have found that the K series motors that have a water/oil cooler have the same setup but on the non-cooled motors there is no lines present at all.
So going off of that I would say you would be fine removing them.
Here's a K series that has been 'retrofitted' with a oil cooler...
Oh and the fitting you were wondering about...
https://www.s2ki.com/forums/index.ph...f=142&t=639263
S2BOOSTED
Sep 8, 2010 02:33 PM
