replacing clutch with blower
Old Mar 10, 2011 | 04:16 PM
erikvanden's Avatar
Default replacing clutch with blower
me and a couple of my buddies who have a lot more knowledge under the hood then I are planning on doing a clutch job this weekend. I know many people who have superchargers were able to replace the clutch without having to take off the blower via tilting the engine back verses lowering the entire engine. I was wondering what steps were different in the install when going this route. I would assume that a lot of the steps that needed to be done before getting under the car wouldn't be needed as you wouldn't be able to access them with the blower in the way.
Old Mar 10, 2011 | 04:29 PM
RacerXI's Avatar
You'll need to pull the aftercooler, the SC can stay. It will be resting on the cross member when you lower the subframe. Take the drive belt tensioner out and you'll have 3X the room to get the top starter bolt out.
Old Mar 10, 2011 | 07:17 PM
JuicedS2K's Avatar
Pull your knock sensor as well, it is very likely you will crack it while taking that starter bolt out.
Old Mar 10, 2011 | 07:50 PM
erikvanden's Avatar
Do you mean the AC will be resting on the cross member or the blower head? If it is the blower head wouldn't I need to unbolt it?
Did you mean if I don't take out the knock sensor out I will most likely crack it? Could I also get a picture or something of the location of the knock sensor just to make sure I don't forget it?
Thanks for the help
EDIT: I am guessing the main difference between the regular method and tilt method is in the tilt method you just undo the back and middle bolts in the subframe enough for the engine to tilt, not the front ones.
armthehomeless
Jan 9, 2013 05:38 PM
raymo19
Mar 8, 2011 04:19 PM
LuckyStar
May 5, 2007 01:57 PM
Partshelper
Oct 26, 2006 12:03 PM
duff0000
Mar 27, 2006 01:59 PM
