Replacing Driver Side Engine Mount
Old Dec 24, 2012 | 09:21 AM
rikhemi's Avatar
Default Replacing Driver Side Engine Mount
Hey guys,
Just wanted to make sure if I would need to do anything special to get my driver side engine mount removed from the car. Normally I would have unbolted both engine mounts, dropped the sub frame 1-2 inches and then lifted the engine from the oil pan. Since I can’t get to the passenger side mount due to my turbo, is there anything specific I would need to do to replace this mount?
Thanks in advance.
Old Dec 24, 2012 | 09:49 AM
o'malley_808's Avatar
Nope should be straight forward. Top mount or bottom kit? Drop the subframe? That isn't necessary...
Old Dec 25, 2012 | 03:37 AM
CoolGuy094's Avatar
Yeah you don't need to drop the subframe. Just unbolt both engine mounts from below and jack the engine up a bit. You will probably have to work in there and unbolt the metal bracket that attaches the engine mount to the block (four bolts I believe) and remove that bracket and the engine mount as one piece. I don't think there is a good way to get at the big top nut on that assembly with it still on the car.
Its a bit of a PITA, and a set of ratcheting closed-end wrenches would have helped me to get the job done about twice as fast.
Old Dec 25, 2012 | 04:19 AM
Corey Maurer's Avatar
Yes wracheting wrenches are your friend here! Easy swap with the motor subframe and all accesories still attached tho
Old Dec 25, 2012 | 06:18 AM
rikhemi's Avatar
Got it. I did think about removing the bracket but it seemed to be pretty tough to get to the top bolts from under the car. Ill look into buying a wracheting wrench. Thanks for your replies. Happy Holidays
Jwilly571
Aug 31, 2018 05:24 AM
p0staboy
Southern Ontario For Sale
Jul 7, 2014 06:54 AM
rikhemi
Apr 4, 2013 06:24 AM
slavka
Jun 7, 2004 06:26 PM
